JDM H22 4door Baseline Dyno VIDEO!!
Old Sep 2, 2004 | 12:48 PM
Ransom's Avatar
Default JDM H22 4door Baseline Dyno VIDEO!!
Got bored today and decided i would take a trip down to trackmasters and get a few baseline dynos...Im a little dissapointed in the numbers i put down, but i also have a slight miss at idle, which is prolly hurting my numbers a little bit.
Mods:Carbon fiber short ram intake, 2.25 crush bent on a N1 axleback. Chipped p28.
Blue-JDMshit h22a program
Red- Custom Allmotor from ih8ricerz
Green-Mugen from ih8ricerz
Videohttp://www.we-todd-did-racing....DE%3D
Modified by LudeSH at 10:52 PM 9/2/2004
Old Sep 2, 2004 | 03:18 PM
Pat McGroin's Avatar
Default Re: JDM H22 4door Baseline Dyno VIDEO!! (LudeSH)
JDMshit has a smooth powerband.
The others just have a sudden spike right when Vtec kicks. I wonder how a spoon program will do.
Old Sep 2, 2004 | 03:20 PM
99B16Si's Avatar
yea but its lean as hell
Old Sep 2, 2004 | 03:37 PM
Ransom's Avatar
Default Re: (99B16Si)
Yup the the jdmshit program was lean as hell...Ill soon have hondata though
Old Sep 2, 2004 | 07:53 PM
Ransom's Avatar
Default Re: (LudeSH)
Heres the vid http://www.we-todd-did-racing....DE%3D
Old Sep 2, 2004 | 10:17 PM
donkiman's Avatar
lets see some pics of the install!!
Old Sep 3, 2004 | 01:41 AM
jdmh22eg's Avatar
what mounts are you using?
Old Sep 3, 2004 | 07:23 AM
Ransom's Avatar
Default Re: (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">lets see some pics of the install!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22eg &raquo;</TD></TR><TR><TD CLASS="quote">what mounts are you using?</TD></TR></TABLE>
HCP mounts
Old Sep 3, 2004 | 07:53 AM
WAFFLES's Avatar
Upping the FP would help that out some.
Good post.
Old Sep 3, 2004 | 11:19 AM
Ransom's Avatar
Default Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">Upping the FP would help that out some.
Good post. </TD></TR></TABLE>
He said upping the pressure i could grab a couple of ponies out of it...I have one comming though
Old Sep 3, 2004 | 11:30 AM
mrbsponge's Avatar
real nice numbers bro, only gonna get better too
Old Sep 3, 2004 | 02:51 PM
Newman's Avatar
New User
Default Re: (mrbsponge)
Use a FPR and bump the fuel pressure up a bit and you'll be fine. The program that we have is based off of the JDM Prelude Type S maps and have it slightly modified to run well on a H22A motor in the P28 ECU. The powerband is nice & smooth with our chip, as shown on your dyno. The "Mugen" program is most likely a B-series ECU program and when I've used them in the past, there's a lag in the midrange powerband until VTEC, and then it picks up again.... shows just that on the dyno chart. Obviously if you have the funds & resources, get a Hondata so you can tune it to your motor's fullest potential.
BTW, I've seen a Spoon P13 dyno chart and the gains are also pretty smooth. Not a sudden jump or surge on the chart with the Spoon program on the P13.
Old Sep 3, 2004 | 04:50 PM
slrh22hatch's Avatar
Default Re: (Newman)
Arent those numbers kind of low??? Newman did program that chip with hondata for ur hatch?????
Old Sep 4, 2004 | 01:00 AM
jdmh22eg's Avatar
lovin tha intake...
Old Sep 4, 2004 | 02:25 AM
Ransom's Avatar
Default Re: (slrh22hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slrh22hatch &raquo;</TD></TR><TR><TD CLASS="quote">Arent those numbers kind of low??? Newman did program that chip with hondata for ur hatch????? </TD></TR></TABLE>
Yeah like i said i have a miss at idle which is prolly causing my numbers to be a little low...But what are you talking about newman programing the chip for my hatch...I dont have a hatch
Old Sep 4, 2004 | 02:27 AM
Ransom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Use a FPR and bump the fuel pressure up a bit and you'll be fine. The program that we have is based off of the JDM Prelude Type S maps and have it slightly modified to run well on a H22A motor in the P28 ECU. The powerband is nice & smooth with our chip, as shown on your dyno. The "Mugen" program is most likely a B-series ECU program and when I've used them in the past, there's a lag in the midrange powerband until VTEC, and then it picks up again.... shows just that on the dyno chart. Obviously if you have the funds & resources, get a Hondata so you can tune it to your motor's fullest potential.
BTW, I've seen a Spoon P13 dyno chart and the gains are also pretty smooth. Not a sudden jump or surge on the chart with the Spoon program on the P13.</TD></TR></TABLE>
I like the h22 chip better then the b series mugen program i have...like you said the power is a hell of a lot smoother...I have a FPR on the way though so that will be taken care of Hondata is in the near future
Old Sep 4, 2004 | 07:25 AM
PHiZ's Avatar
Red and green are the same program with different vtec engagment points.
-PHiZ
Old Sep 6, 2004 | 11:04 AM
civicsitek GanGsTa's Avatar
Default Re: (PHiZ)
2.25" crush bend pipe isn't helping. Looks like the jdmsh!t chip has an earlier vtec switchover.
Old Sep 7, 2004 | 02:16 AM
n-line4's Avatar
I want that intake! heh
Old Sep 7, 2004 | 06:13 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeSH &raquo;</TD></TR><TR><TD CLASS="quote">Yup the the jdmshit program was lean as hell...Ill soon have hondata though </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">yea but its lean as hell</TD></TR></TABLE>
2-3 PSI on an FPR and I bet it's near perfect.
Every motor is different, as well as conditions and dynos.
Old Sep 10, 2004 | 09:56 AM
I was asking Newman If he made that chip for his hatch ??? And did he make it with Hondata??? Cause I have the chip also. I havent dyno'd it yet.
Old Sep 10, 2004 | 10:22 AM
Adam.'s Avatar
I was asking Newman If he made that chip for his hatch ??? And did he make it with Hondata??? Cause I have the chip also. I havent dyno'd it yet. </TD></TR></TABLE>
He made it for his bolton h22 hatch that he road races.
Old Sep 12, 2004 | 02:35 AM
94_HATCH's Avatar
Finally!!! Thats all i needed to see. sending my p28 to newman on monday. Thanks to original poster for taking the time to do this
Old Sep 12, 2004 | 09:49 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (94_HATCH)
The AF looks horrible if you ask me... too lean in between 5 and 7k RPM, nor is the AFR consistent throughout the RPM band.
Old Sep 12, 2004 | 11:35 AM
ludedude48's Avatar
Default Re: (LSVTEC 91 Civic)
I replaced the h22 jdm A/T cams for the M/T that were in my USDM h22. I got a little different power band, some more torque and about 177whp. It was a pretty inexpensive upgrade considering I had the cams already.
93 Lude
H22jdm
I/H/C/E
USDM M/T cams
15" stock rims
sticky clutch and a not-too-heavy flywheel
-16 1/2 TDC
http://www.bristoldyno.com/veh..._Luke/
177.6 whp
15_ Wtq
Modified by ludedude48 at 3:47 PM 9/12/2004
