Used ecu
Old Sep 2, 2004 | 12:27 PM
Ronin150's Avatar
Default Used ecu
I want to do a zc engine swap, and I need a new ecu for my car. I found one at this parts store, but they said it might not work. Is it possible for the ecu to be damaged and is there any way that I would be able to get it fixed. They want $75 for it. thanks for the help
Old Sep 2, 2004 | 12:28 PM
Outsane's Avatar
Default Re: Used ecu (Ronin150)
if its damaged, it could be a simple fix..but mostt likely if its damaged its trash...
See if the parts store will let you test it...before you buy..
Old Sep 2, 2004 | 12:30 PM
Ronin150's Avatar
Default Re: Used ecu (Outsane)
how can I test it before I buy it. In all honesty I don't know where my ecu is.
Old Sep 2, 2004 | 12:31 PM
EP3_05's Avatar
You can try plugging it into your car or a friends and see. When you try to start the car check the little window on the ecu. If it the light is on constantly the ecu is toast. Like the other guy said it could be a simple fix or complete trash. Try buying one out of the classifieds on here. I see OBD0 ecus for sale all the time for reasonable prices.
Old Sep 2, 2004 | 12:33 PM
Ronin150's Avatar
Default Re: Used ecu (91civic)
Where is my ecu at? I also have the crx dx, can I still be able to test the ecu?
Old Sep 2, 2004 | 12:35 PM
EP3_05's Avatar
The ecu is under the carpet and a metal plate in the passenger footwell. The plate is held down with 4 10mm nuts. No you cannot test the ecu since the you are running a dpfi wiring setup. You need to test the ecu on an mpfi setup.
Old Sep 2, 2004 | 12:40 PM
Ronin150's Avatar
That's what I thought. I might just buy one from a h-t member. I would rather not take the chance of it not working. Thanks for the help everyone.
Old Sep 2, 2004 | 02:10 PM
92integra_gs's Avatar
yea just buy it off a trust worthy realiable HT member... its cheaper and better off than trusting those damn parts store which rips you off....
Old Sep 2, 2004 | 06:38 PM
nuc79's Avatar
if you're doing a dohc ZC, make sure you get the 88-89 teg PG7 ecu(good), or JDM PM7 ecu(better).
Or 90-91 pm6 ECU (from Si/EX) which will need chipped for optimal performance w/ the dohc zc, but tunable using TurboEdit for future upgrades (best).
I did a ZC swap last saturday in a CRX. very easy, cheap swap w/ good returns
mita
Aug 28, 2014 11:46 PM
_HANS
Jun 13, 2004 03:33 PM
