......help..... how to replace speedo cable ?
I need to replace my speedo cable cause the end of it broke.
Someone told me that I had to take off the dash and the cluster.
Where or what exactly to do i need to take off?
You have to take your gauge cluster out and disconnect the speedo cable, there is a rubber bushing that holds the cable in the firewall that you have to pull out. And than on the back of the tranny pull the rubber up and pull the "C" type clip off and pull the cable out.
Whenever you replace a cable, tie a piece of string onto the end of it before pulling it out. Then tie the same piece of string onto the end of the new one. This way, you just pull it back through with the string. And you don't have to worry about trying to make the cable go through the right holes and nooks and crannies. It just makes the job ALOT easier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Whenever you replace a cable, tie a piece of string onto the end of it before pulling it out. Then tie the same piece of string onto the end of the new one. This way, you just pull it back through with the string. And you don't have to worry about trying to make the cable go through the right holes and nooks and crannies. It just makes the job ALOT easier.</TD></TR></TABLE>
great info!
great info!
LSVTEC 91 Civic
Mar 20, 2004 07:08 AM
