SIR Guage Cluster in 89 Crx DX
I just bought a CRX Sir Guage cluster, and when i tried to plug it up. I realized that all of the plugs are different. But Hmotorsonline was nice enough to provide the SIR plugs with about 5 inches of wire on them. Does anyone know where i can get a diagram on how to wire up a SIR guage cluster?
Pin outs of both cars, or what each wire is for. Anything would help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. »</TD></TR><TR><TD CLASS="quote">cluster 411
Remember, that write-up is for '90-91 cars. The '88-89 gauge clusters have different wiring.
You'll need the wiring diagrams for the '88-89 to '90-91 conversions on hand, in addition to the SiR cluster diagram. You should be able to find them in a search.
You'll also need a '90-91 cluster hood to install it in your '89 car.
</TD></TR></TABLE>Remember, that write-up is for '90-91 cars. The '88-89 gauge clusters have different wiring.
I will make sure to take pictures and post them when i do it. I will not get to do it this weekend again though. Because i live in south florida, and we are going through a hurricane right now.
here you guys go! i got an 88 crx si, i've done the jdm sir conversion completely. my cluster is 100% done. if you go to yahoo.com use the search and type up "jdm crx sir gauge wiring" then your results will show a site called crx choas.uk.co.
click on that web site. it has "how to" on wiring up the sir cluster. it tells you how to do it, and what you need. careful theres a couple of wires that go together from the sir before they go to one from the si. use the vss from 92-95 civic, remove rear motor mount make a few cuts with a grind and that's pretty much it
if you do it right everything will work!
IM if you have questions. - jason
B16Blake
Nov 10, 2009 10:15 PM
Starbucks_91b16acrx
Oct 10, 2003 08:54 AM
LB CRX
14
Aug 31, 2002 08:34 PM
89 EF
May 23, 2002 09:49 AM
