Would DC Headers for a B16a fit a B18b LS motor?
Old Sep 1, 2004 | 08:37 PM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Default Would DC 4-1 Headers for a B16a fit a B18b LS motor?
these are DC 4-1 headers by the way
Old Sep 1, 2004 | 08:46 PM
Luserkid's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (mario82686)
They might <---- thats a 75% sure answer thinking on the "all b series part is interchangeable rule" But then i think thats different with VTEC and non VTEC (thats why its 75.
Old Sep 1, 2004 | 08:54 PM
DOHCtorTHRUST's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (Luserkid)
it has been known that b16 header will fit b18, i've personally havent seen it, however i was reading a thread the other day and a guy had it on his b series. he said that it was a tight fit but it worked....
Old Sep 1, 2004 | 11:02 PM
THE GAME IS THICK's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (DOHCtorTHRUST)
Yes, all B-Series headers' are interchangable. The only thing i would doubt is A/C clearance issues on some headers' and the header B-Series engine from the old Prelude (Not sure which gen. from the top of my head) also the header from 1st gen CRV's if i am correct.
Old Sep 2, 2004 | 06:10 AM
DrunkNRacer's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (HYPHYBOY)
Yes, there isnt any clearance problems either. DC headers have a short forward length, no contact to anything at all.
Old Sep 2, 2004 | 06:11 AM
hybrid_vtec's Avatar
It depends on what kind of car it is in! Mine fits in my EG w/ B18b just fine!
Old Sep 2, 2004 | 09:51 AM
smart monkey's Avatar
you might have a issue with the clearance of the oil pan. since the ls has a taller block
Old Sep 2, 2004 | 10:26 AM
Combustion Contraption's Avatar
No. I had this about 4 or 5 months ago. It was fine. It is tight around the oil pan, but it works.
Old Sep 2, 2004 | 11:23 AM
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (smart monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">you might have a issue with the clearance of the oil pan. since the ls has a taller block</TD></TR></TABLE>
On my DC 4-1(ceramic) there was no clearance, however on my ITR 4-1 w/ 2.5" collector(SS) I had to modify the oilpan to make it fit so the oilpan wasnt touching the header!
Old Nov 1, 2004 | 11:23 PM
mario82686's Avatar
they fit thanx y0
Old Nov 2, 2004 | 04:23 AM
aut0tek's Avatar
The LS block is taller??? Well damn ya learn something new every day.
Old Nov 2, 2004 | 05:29 AM
rev limiter's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (aut0tek)
The heigt difference betweeb b16a and b18 is about 8.8 mm. I have a friend who swapped out his b16a and swapped in a b18c type R and kept his dc sports 4-2-1 one piece header. Now the header is touching the oil pan.
Old Nov 2, 2004 | 05:49 AM
Rollo Lawson's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (rev limiter)
[QUOTE=rev limiter]The heigt difference betweeb b16a and b18 is about 8.8 mm. [QUOTE]
no, its 7mm.
Old Nov 2, 2004 | 02:18 PM
aut0tek's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (B16C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev limiter &raquo;</TD></TR><TR><TD CLASS="quote">The heigt difference betweeb b16a and b18 is about 8.8 mm. I have a friend who swapped out his b16a and swapped in a b18c type R and kept his dc sports 4-2-1 one piece header. Now the header is touching the oil pan.</TD></TR></TABLE>
So... before the swap, dude's header only cleared the oilpan by less than 7 mm? If it touches the oilpan now... maybe you should torque the oilpan bolts more.
I've used any size header you can possibly come up with, b16, ls, gsr... etc. etc. and guess how many of them didn't fit my LS/VTEC swap?
None.
Old Nov 2, 2004 | 02:21 PM
System-7's Avatar
well you can't use b16 headers on and ls block. gotta got with ls or gsr
Old Nov 2, 2004 | 04:12 PM
Pondus's Avatar
[QUOTE=B16C1][QUOTE=rev limiter]The heigt difference betweeb b16a and b18 is about 8.8 mm. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
no, its 7mm.</TD></TR></TABLE>
No he's right it's 8.8mm, 203.2mm vs 212mm
http://www.raceseek.com/honda_specs.htm
Old Nov 2, 2004 | 04:26 PM
Default Re: (System-7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by System-7 &raquo;</TD></TR><TR><TD CLASS="quote">well you can't use b16 headers on and ls block. gotta got with ls or gsr</TD></TR></TABLE>
When I blew my B16 and replaced it with a B18b, I transfered my DC 4-1 header over with no problem at all and no clearance issues! However when I got a JDM 98 ITR Exhaust manifold with 2.5" collector it rubbed the bottom of the oilpan, so I torched my oilpan and bent it in a lil on the coner to make it fit w/o touching the oil pan! I know this sounds ghetto but how else was I supposed to fit it on properly!
Old Nov 2, 2004 | 04:47 PM
chad's Avatar
Moderator
header
Old Nov 2, 2004 | 04:48 PM
aut0tek's Avatar
Default Re: (hybrid_vtec)
You just measured the deck height... That is not the height of the entire block. Deck height == distance from deck of the block to the center of the main journals. NOT the bottom of the oilpan.
... But even if it were 8.8mm That still means that homie's header had 1/4" clearance on the old one!?!? There was something wrong to begin with. I've never seen a header come 1/4" to the oilpan on a b16 when it was MADE to fit.
Ratliff
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">it has been known that b16 header will fit b18, i've personally havent seen it, however i was reading a thread the other day and a guy had it on his b series. he said that it was a tight fit but it worked....</TD></TR></TABLE>
THAT IS NOT CORRECT!!!!!!!!!!!!!!!!!!!! a header made for a b16 WILL NOT ALWAYS FIT!!!!!!!!!!!!!!!!!.......but a header for a b18 will fit a b16
Old Nov 2, 2004 | 04:49 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYPHYBOY &raquo;</TD></TR><TR><TD CLASS="quote">Yes, all B-Series headers' are interchangable. The only thing i would doubt is A/C clearance issues on some headers' and the header B-Series engine from the old Prelude (Not sure which gen. from the top of my head) also the header from 1st gen CRV's if i am correct. </TD></TR></TABLE>
once again WRONG!!!!
Old Nov 2, 2004 | 04:51 PM
aut0tek's Avatar
Default Re: Would DC 4-1 Headers for a B16a fit a B18b LS motor? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">THAT IS NOT CORRECT!!!!!!!!!!!!!!!!!!!! a header made for a b16 WILL NOT ALWAYS FIT!!!!!!!!!!!!!!!!!.......but a header for a b18 will fit a b16</TD></TR></TABLE>
Teh Gangsta speaks. ;-)
(bows down to chad)
BTW chad sez I'm wrong so sorry... I'll go color now. ;-) good info tho!
Old Nov 2, 2004 | 04:52 PM
chad's Avatar
Moderator
i have 2 dc sports headers at the shop that will not fit b18's or b20's because it was made for a b16.....
Old Nov 3, 2004 | 02:08 AM
Default Re: (aut0tek)
Hee aut0tek chill.
I just give an example so it proves that b16 headers not always fit b18.
And it is not onle the difference in block height. Oil pan are different too. You can't fit a b16 oil pan onto a b18 engine. So there are diffence too that can make the b16 header to touch the oil pan.
And by the way i am not talking any header. This is for the dc sports 4-2-1 one piece header. I can't speak for other headers.
o0oz
Oct 4, 2006 09:50 PM
TRU_Luck
Apr 28, 2006 01:53 AM
M0nK3e.StyLeZ
15
Mar 30, 2005 07:04 PM
JDMspecDA6
Mar 11, 2003 04:54 PM
B16A1-EF9
Oct 13, 2001 06:00 AM
