Anyone running 1mm oversized valves with cams that have at least 12.4mm of lift (H22)???
Old Sep 1, 2004 | 06:57 PM
Rick Solis's Avatar
Default Anyone running 1mm oversized valves with cams that have at least 12.4mm of lift (H22)???
Im getting mixed reviews on this topic... Some say go for it, some say it wont work...
Im just curious if anyone out there has run 1mm oversized valves with cams that have anywhere from 12.3 - 12.8mm lift (H22 specific)??
If so, were there any major valve to valve clearance issues?
Old Sep 1, 2004 | 07:05 PM
satan_srv's Avatar
Default Re: Anyone running 1mm oversized valves with cams that have at least 12.4mm of lift (H22)??? (Rick S
I would say it depends on what pistons you are running...some aftermarket pistons have much larger valve reliefs
Old Sep 1, 2004 | 08:33 PM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">I would say it depends on what pistons you are running...some aftermarket pistons have much larger valve reliefs</TD></TR></TABLE>
Piston to valve clearance isnt the issue... Its valve to valve clearance that Im conserned about...
Old Sep 1, 2004 | 09:12 PM
TYPERman2001's Avatar
* B A N N E D *
my friend runs rev 1mm over sized vaLVES on his full prelude
stock block, stock cams fully built head dynoed 228 on shawn church dyno
Old Sep 1, 2004 | 09:16 PM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPERman2001 &raquo;</TD></TR><TR><TD CLASS="quote">my friend runs rev 1mm over sized vaLVES on his full prelude
stock block, stock cams fully built head dynoed 228 on shawn church dyno </TD></TR></TABLE>
yeah, I know you can run 1mm oversized valves with stock cams... I was just curious if anyone had any experience running them with an aftermarket cam, something with some decent lift (12.3'ish)
The issue in question is valve to valve clearance...
Old Sep 1, 2004 | 09:18 PM
* B A N N E D *
we check valve cleareance with jun cams and it was prettty close so we decided to run stock cams to be on safe side
Old Sep 1, 2004 | 09:21 PM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPERman2001 &raquo;</TD></TR><TR><TD CLASS="quote">we check valve cleareance with jun cams and it was prettty close so we decided to run stock cams to be on safe side </TD></TR></TABLE>
What was the v to v clearance at with the JUN cams?
Old Sep 2, 2004 | 06:31 AM
LudeyKrus's Avatar
So you chose to run oversize valves instead of bigger cams?!
Old Sep 2, 2004 | 06:39 AM
* B A N N E D *
for the time being yeah cause the head was designed for oversized valves
got a new head and going full jun valve train with my jun cams
and got my rs machine motor back 90 mill 14++ compression shopuld be a fun motor
Old Sep 2, 2004 | 08:22 AM
Mr Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">
The issue in question is valve to valve clearance...</TD></TR></TABLE>
Look in TBone's All-Motor build thread, he ran into problems with v-v clearance on Jun4's or something insane. But I don't know the lift specs, or if his valves were oversized (I'm guessing they were since every inch of that motor was built hard-core).
CTCD5
Oct 22, 2014 07:23 AM
urtz
Jun 18, 2007 01:30 PM
Revi
Sep 22, 2006 09:51 AM
hu
Jul 12, 2006 10:08 AM
Rick Solis
Oct 26, 2004 11:09 AM
