where else can i get power??
Old Sep 1, 2004 | 06:06 PM
hatchinprogress's Avatar
Default where else can i get power??
i just got my msd ignition (6btm) today and it has the instructions, but i was reading and i need power (of course) but my problem is i have my battery in the back so is there any other place i can get power for the ignition?? i dont wanna have to run more wire to rear if i dont have to
Old Sep 1, 2004 | 06:28 PM
AgentJam's Avatar
Default Re: where else can i get power?? (hatchinprogress)
mines wired to the under hood fuse box...the white wire that goes to the starter is like an 8 gauge that runs right from it to the starter.
Vince
Old Sep 1, 2004 | 06:34 PM
Default Re: where else can i get power?? (AgentJam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AgentJam &raquo;</TD></TR><TR><TD CLASS="quote">mines wired to the under hood fuse box...the white wire that goes to the starter is like an 8 gauge that runs right from it to the starter.
Vince</TD></TR></TABLE>is that safe to run my ignition power with my starter power?? (i dont know so i just wanna make sure)
Old Sep 2, 2004 | 03:39 AM
AgentJam's Avatar
i didn't actually cut the starter wire and splice into it....what i did was crimp an end on it so i could screw it into the fuse box with the power wire that you should have run from the battery to the fuse box. Both the battery + wire and the starter + wire run to the same side of the fuse box. Just pop it open and you'll see.
I used the power wire from the battery but from your original post it sounded like you didn't know you could do that?
Basically just follow the white wire to the spot on the fuse box. 3 mm to the left of it is where you should have run your power wire.
Vince
Old Sep 2, 2004 | 07:10 AM
thanks
ahem ahem
Aug 23, 2009 06:28 PM
0TT
Dec 31, 2007 11:49 AM
bayoufrogg
Oct 24, 2006 08:18 PM
Lude@Heart
10
Jul 27, 2006 04:52 AM
Nisif
Nov 3, 2005 08:34 PM
