wiring for si dizzy to dx harness.
im doing dpfi to mpfi i ran the c1 and c2 wires back to the dizzy there not connected to anything at the moment but i cant figure out what goes where i have it all color coded now but it wont start. anyone got a graph i searched but the colors on everyone elses dx harness are diffrent. ill make a drawing if u want...
dunno what this is but its broke what should i do?
anyone know where this hose goes? the only one i cant find a home for.
dx harness=
2 solid white's
blue / yellow c2 (i wiredto ecu)
blue / green c1 (i wired to ecu)
1 solid orange
1 blue / orange
1 blue / white
si dizzy=
1 blue / green assuming its the c1
1 blue / yellow also assumings its the c2
1 blue / white
1 blue / orange
1 solid orange
2 solid whites
i dont have the plugs for the si dizzy or anything so i gota hardwire it.
Modified by sekz at 7:34 PM 9/1/2004
Modified by sekz at 7:42 PM 9/1/2004
dx harness=
2 solid white's
1 solid orange
1 blue / orange
1 blue / white
si dizzy=
1 blue / white
1 blue / orange
1 solid orange
2 solid whites
From: I told you to wait in the truck in Texas, United States
If you don't have those two wires connected,
It will not start in the MPFI configuration because
that is the cylinder position sensor.. It needs to have that hooked up
to sequentially fire the four injectors..
You are using an Si or HF distributor right?
thanks dude but i can barly see what wires are witch on the si sizzy cant u just say what goes to what in text format? what do i do with the left over white wire from the harness?
dx harness=
2 solid white's
1 solid orange
1 blue / orange
1 blue / white
si dizzy=
1 blue / white
1 blue / orange
1 solid orange
2 solid whites
dx harness=
2 solid white's
1 solid orange
1 blue / orange
1 blue / white
si dizzy=
1 blue / white
1 blue / orange
1 solid orange
2 solid whites
As long as the colors match up it doesnt matter how you wire it up to the harness plugs. For the 2 white wires, just take a guess. If it runs like crap, swap them around.
DX harness >>>>>>>>>>>>&g t;Si distributor
blue from harness hooks to: blue from distrib
blue/yellow from harness hooks to: blue/yellow from distrib
tan hooks to white
orange hooks to orange
white to white
orange/blue hooks to orange/blue
white/blue hooks to white/blue
good luck bro..
Modified by 88DXCRX at 5:43 PM 9/2/2004
tan hooks to white
white to white
good luck bro..
my igniter was bad and there was all kinds of **** int he distro. it runs but idles like *** due to the intake manifold gasket
its all broken so i ordered 1
Sorry if I confused ya..Looked kind of tan to me.
These guys called them peach: http://www.dmoore.com/crx/zc-phase3.htm
I looked at the schematic in the Helms manual
and they call them orange also.
95f22a1
22
Feb 2, 2009 10:12 AM
JDMlyfestyle
Oct 16, 2004 07:04 PM
