Best and easiest way to remove window tint?
My hatch's tint is turning purple and I want to remove it. How should I go about doing this? The tint is the sticker type. Should I just peel it off or will that leave bad results underneath on the window?
Got a tire iron?
No but really just peel it and use a soapy water sloution and then just a razor blade and scrape.... it takes a little while...
What other help does he need? A Soapy water solution and a razor blade takes tint right off of windows. Ive used that method for any car I have had with tint....
You peel off the tint and then with the soapy water spread over the residue. Give it 5 min to soak in, then with razor blade lightly scrape away glue left on windows. And for safety sake push razor blade away from you just in case u slip... no need for u to cut yourself!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdanglez »</TD></TR><TR><TD CLASS="quote">Well ...to remove the tint we used simple green and razorblade .....
first make a cut on the other most park of the window.....becareful do not cut the glass!!! this takes time!! After u have a fold begin tear it downward...try to tear in it in huge chucks so u don't have to use the razor blade that often....when pullin the tint down spray sum simple green on the part of window that does not have the tint anymore this helps remove the tint easier and faster!!! after the tint is off u gonna have spray simple green like a mad man!!! now u gotta remove the adhesive .......then just start cleaning........i noticed sum streaks...when i was done so i sprayed sum
to help us out....this is the whole process pretty simple just take ur time.....
oh yeah simple green works great on cleaning engines!!!</TD></TR></TABLE>
to help us out....this is the whole process pretty simple just take ur time..... oh yeah simple green works great on cleaning engines!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDReh2 »</TD></TR><TR><TD CLASS="quote">pay a tint shop like 30 bucks or so to take it off with the special chemical ****....its the easiest way</TD></TR></TABLE>
30 bucks! HAHA it cost me 100 just for the rear. Because its almost impossible not to cutt he defrosters and if they do they dont wanna get screwed and have to replace it. But like everyone else said. Peel it off, then take window cleaner/water and soap soultion, spray it on the window and scrape with a razor blade (of course holding it flat). No need for other methods. Thats how you get it done. Sure theres probably ways to tweak it a little but thats all you need to know, peel, spray, scrape, wipe with a damp cloth to get the soap off. And you done, lock this thread now so no one else can post and possibly confuse everyone and avoid about 20 more topics in the a/c sections about removing tint that were sprung off of this one.
Guest
Posts: n/a
I dont like solutions and waiting. I did mine perfectly with a heatgun, take your time with the heatgun or you will spend 3x as much time scraping the adhesive off. I can do 5 windows perfectly in about 30 minutes.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2integra2001 »</TD></TR><TR><TD CLASS="quote">i just took my tints off my DA n only took me like 7-10 min.... i just used a razer blade n water..thats it</TD></TR></TABLE>
I bet anything theres glue all over your windows
Try rolling them down
I just peeled them off. Left hardly any adhesive since I did it slowly. Took about 30 minutes. Didn't even use a razor either. Used some acetone to clean up the remaining adhesive.
i got the same problem. but mines is for the back window. i was told that your shouldnt use a razor for the back window because it will cause more work due to the heating electrical lines.. i need some major help too. im trying to save a few bucks i just got my car out of the shop and it cost me a bundle. please help. anything to make me save a few bucks will help.
werd!
werd!
It might take a while but try to get part of it to peel with your nail or a razor blade and peel it in large pieces slowly.
OMG I just tried to take off my tint, i think its old so its turning purple. Anyways, I used Dishwashing Detergant, water, and a bottle of Windex. I peeled the "film" off of it, and then began to work at the sticky film. I used water + Dish washing detergant on the sticky, and let it sit for 5 minutes. And yes, it dried up! WTF!
Okay now i got a driver side window i cant see through. Someone help me out here, what was i doing wrong? It took me 15 minutes to get like 1/3 of a ich off of the tint.... Should I go get some Simple Green? BUMP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P h i »</TD></TR><TR><TD CLASS="quote">tint sucks</TD></TR></TABLE>
hell yas espescially gettin the **** off the rear window, w/ the defroster
for the back just sweat it off so you dont **** up the defroster,
1st spray it down real good with windex
2nd, tape a big black trash bag to the inside of the window
3rd , wait till it starts to bubble and peel it off slowly.
oh and it has to be fairly hot for this to work .
nopppe there was no glue or any of that goowey stuff left over...n wen i peeled them off ... the tint came off in big peices...the driver n passanger side window was the easiest..came off in 1 big peice
j/k i was wondering this 2 cuz it happend 2 my gf car
