help what to know how to hook a air to fule recho gage up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro »</TD></TR><TR><TD CLASS="quote">Not hard at all. You have to tap into switched power/02 sensor wiring and ground. </TD></TR></TABLE> could you tell me (us) were the "switched power/o2 sensor" is??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nurvcom »</TD></TR><TR><TD CLASS="quote">ya where is the switched power/o2 sensor</TD></TR></TABLE> cuz i have one but i dont know how to hook it up i would like to know also
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHiTe91hAtChBaCk »</TD></TR><TR><TD CLASS="quote">wrong forum....this is pre 91...post in eg..but its all good..if i knew i would help...sorry</TD></TR></TABLE>
word.. but if you want, you can take the signal wire off your O2. and run it to your A/F gauge, and call it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nurvcom »</TD></TR><TR><TD CLASS="quote">but where is it located?</TD></TR></TABLE>
Trace the ****! You know where the O2 sensor is right? It feeds a signal to the ECU so just use a splice connector to tap into that wire. I'm not familiar enough with EF's to know where a good switched 12v is but on my M3 I tapped into the 12v feeding the instrument cluster.
b20vtecEK
Mar 30, 2005 01:04 PM
nkt001
11
Oct 21, 2004 03:35 PM
