Wheel experts...question about offset on ITR
Old Dec 5, 2001 | 06:51 PM
Todd00's Avatar
I said I don't want a title!
Default Wheel experts...question about offset on ITR
I need a set of autox wheels and I was looking at some 15x8's with 32mm offset. Now, I know these will stick out past the fender, which is ok becausethat's the fast way anyhow I will be running springrates high enough so that I won't have to worry about rubbing. Tires will be 225/50/15 Hoosiers.
However, what's the backspacing on a 15x8 at 32mm? I want to make sure they aren't too close to an control arm or something.
Thanks.
Old Dec 5, 2001 | 06:57 PM
Big Phat R's Avatar
Default Re: Wheel experts...question about offset on ITR (Todd00)
that's a tough one. try IM 2fknfst - he runs 8" rims on his R with 3mm spacers I think. Not sure about the offset though.
Old Dec 5, 2001 | 06:59 PM
Cosworth's Avatar
Default Re: Wheel experts...question about offset on ITR (Big Phat R)
2fknfst runs 16x8 mazda RX7 rims with 38mm (?) offset + the spacer. Ask him or BlackR for the exact offset on those RX7 rims.
BTW, why do you even need 15x8" rims? 15x7" not good enough? Surely, you can't squeeze 245's in there...
Old Dec 5, 2001 | 07:59 PM
Todd00's Avatar
Default Re: Wheel experts...question about offset on ITR (Cosworth)
I'd rather stretch a tire over a 8" wide rim than have a bulge on a 7" rim. More precise handling and a wider contact patch with the 8"
16" wheel/tire is waaay to big. Heck, even a 15" is a little large for a FWD autox car.
Old Dec 5, 2001 | 08:23 PM
Hybrid ctr's Avatar
can someone explain
what exactly is the offset of a wheel
how do you determine what offset you should get
when purchasing wheels
Old Dec 5, 2001 | 11:59 PM
Hybrid ctr's Avatar
Default Re: Wheel experts...question about offset on ITR (Hybrid ctr)
ttt
2kdrift
Suspension & Brakes
Nov 6, 2015 12:19 AM
cappelhans
10
Jan 23, 2006 06:32 AM
veilsides2000
Nov 18, 2003 06:07 PM
clement_h
12
Jul 7, 2003 04:17 AM
9d9GSR
May 21, 2002 12:53 PM
