Good clutch replacement.
Old Sep 1, 2004 | 04:43 PM
Bowers's Avatar
Default Good clutch replacement.
Well I think my clutch is about at the end of it's life, every now and then it will slip and make the horrible burnt smell. What decent aftermarket clutch would be good to go with? I want something with more holding power that the oem clutch but I really don't feel like spending a fortune on either. By the way it's a '99 with some mild upgrades. Thanks!
Old Sep 2, 2004 | 02:51 AM
tuong's Avatar
Default Re: Good clutch replacement. (tunergsr32)
I would not recommend clutch master clutch. I hear bad things about ACT clutch also. I hear it works but its cheaply made. Exedy is a good brand I hear. just make sure u shop around to get that clutch install. it should cost u around 600. depending if you got an sh or not.
Old Sep 2, 2004 | 05:29 AM
CompressionFed's Avatar
Default Re: Good clutch replacement. (tuong)
Comp Clutch
Old Sep 2, 2004 | 09:52 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Good clutch replacement. (CompressionFed)
really depends on what your car has, hp/torque wise and what you'll be using it for. if it's a mild setup, less than 200 hp, i'd say, then you can't go wrong with an exedy organic. great on your wallet and a good clutch.
91crxturbo
Nov 30, 2006 04:29 PM
taffetawhitegsr
Aug 24, 2004 06:16 PM
SilverS
Feb 26, 2002 02:21 PM
