Mass Air Flow Meter location
I was wondering if anybody knew where the location of the mass air flow meter is on a D16Y7 intake manifold. This is important for a new mod i am attempting to create. Any help would be...well... helpful
sry to break it to you but hondas dont have MAF sensors, sry bro, the only thing we get is MAP sensors, and that is usually located on the top of the plenum on the intake and it says MAP right on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">sry to break it to you but hondas dont have MAF sensors, sry bro, the only thing we get is MAP sensors, and that is usually located on the top of the plenum on the intake and it says MAP right on it
This is true. What does MAP stand for anyway
</TD></TR></TABLE>This is true. What does MAP stand for anyway
its a manifold absolure pressure (MAP sensor). intake has 4 sensors, 2 of which share a port. Throttle position is built into the TB. I think the Air intake temp is on the side of the intake box, on the left of the car. There should be another on the TB, and i believe a 3rd. On the TB, i believe on the y7 (this is my engine, I did the mani swap), the manifold pressure sensor should be in the throttle body. the TPS is on the opposite side of your throttle cable mounting plate, meaning 180 degrees on the other side of the throttle hole. check diagrams. If you havent found it in a few days, I will be goin home, and can double check my helms manual. The IACV is where the 2 coolant lines run into. So after these 2, I think the other one I didnt list (and there are 3 wires runnin to the TB) the remaining one is the MAP (manifold absolute pressure) sensor.
joy123
14
Feb 11, 2015 04:06 PM
Discontained
Sep 27, 2006 07:03 AM
