ecu chip question
Old Sep 1, 2004 | 03:19 PM
KillaB-'s Avatar
Default ecu chip question
my engine runs very rich because of my current mugen chip. and it is not slightly rich its running so rich the unburnt fuel washed the cylinder walls and ruins my rings. i am going to get a new chip with more reasonable fuel and ignition maps.
DO i need a VAFC to take full potential/ make my chip work effectively??
thx
Old Sep 1, 2004 | 04:20 PM
apex001's Avatar
Default Re: ecu chip question (KillaB-)
not really but it would help. what is your setup? any cams I/H/E? VAFC will help you tune it but if your ecu is spilling to much fuel, th vafc might help alittle.
Old Sep 1, 2004 | 04:28 PM
KillaB-'s Avatar
Default Re: ecu chip question (apex001)
ITR cams CAI ITR header 2.5 exhaust CTR pitons P&P head by JG
Old Sep 1, 2004 | 07:39 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaB- &raquo;</TD></TR><TR><TD CLASS="quote">
thx</TD></TR></TABLE>
Yes, the VAFC will +/- fuel by 50% at a given RPM point.. You could also use a FPR and lower the fuel pressure.
Old Sep 1, 2004 | 08:08 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaB- &raquo;</TD></TR><TR><TD CLASS="quote">my engine runs very rich because of my current mugen chip. and it is not slightly rich its running so rich the unburnt fuel washed the cylinder walls and ruins my rings. i am going to get a new chip with more reasonable fuel and ignition maps.
get the chip tuned and then you wont need the afc at all and the car will run much better than with the afc
Old Sep 1, 2004 | 11:23 PM
Fobtions's Avatar
Default Re: ecu chip question (b18cls1)
IMO on most setups
a vafc and stock chip &gt; "mugen" chip
the only benefits u get out of those random mugen chips is that ability to rev higher, not needing a o2 sensor, and wasting gas.
If you are serious about tuning the ecu, u need to get on a wideband and tune those mugen maps down.
Old Sep 2, 2004 | 06:59 AM
KillaB-'s Avatar
Default Re: ecu chip question (Fobtions)
i am seriuos, i really want a effective ecu for my street car. ive only heard of a few wide band but dont really know much about them. can you explain it to me
Old Sep 3, 2004 | 08:25 AM
R-Toyz.com's Avatar
if you need a tuned chip pm me or check my sig. running a chip with a vafc tuned at the dyno will help, but nothing as close as a real standalone would. when you're running a mugen chip you'll find yourself turning down the fuel most of the time to get your a/f ratio to optimal levels.
uptownfunk
22
May 15, 2007 05:38 PM
tomlinson619
Jul 18, 2006 01:39 AM
Red D Dragon
May 23, 2004 05:42 PM
conesmasher
Jun 3, 2003 07:27 AM
GsTeg90
Apr 8, 2003 08:23 PM
