Continue New Set for H22 NA..............
Quote, originally posted by RICK SOLIS »
H22 P&P head by LDL Speedshop
Crower Valvetrain There are better options out there for valvetrain
Crower STage 2 awesome bang for buck cam
Findanza Camgears
JG 70mm TB
Skunk2 IM Euro R is a much better option IMO
RC 370 injectors
JDM H22a block
JE pistons Look into CP or Wiseco's offerings
Eagle Rods
p28 w/hondata s200
ACT HDX clutch
Findanza flywheel
MSG digital 6
Header(DC at the moment) gonna get either DTR,hytech, or hotshot race headerHytech or SMSP... for now!
I did not bore,resleeve the block I give you 6 months max before your **** goes south...
So if I did resleeve and didn't bore it out my motor would go out in a few months?
Findanza Camgears
JG 70mm TB
RC 370 injectors
JDM H22a block
Eagle Rods
p28 w/hondata s200
ACT HDX clutch
Findanza flywheel
MSG digital 6
you need to resleeve because of the FRM cyl. lining
SEARCH
https://honda-tech.com/zerothread?id=416069
Read the whole thread
SEARCH
Would there be a difference to have a jdm block or a usd h22 block, the shop that is doing is says once everything gets pulled out jdm or not the block still wouldn't matter?
There is no difference from the JDM and USDM blocks as far as the cyl. linings. If you run forged pistons you MUST sleeve your block.
Yea FRM and Forged Pistons dont work. Well theres theories but you seem not worthy to hear them. So just sleeve your block before you **** yourself in the *** and say damn i should of listened to that bolivian guy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fly1865 »</TD></TR><TR><TD CLASS="quote">There is no difference from the JDM and USDM blocks as far as the cyl. linings. If you run forged pistons you MUST sleeve your block.</TD></TR></TABLE>
Which block is stronger for the NA application and longevity? JDM or USDM? So if I sleeve the block do I have to bore it out as well? Someone told me that if I don't bore out the block and just sleeve then my motor will go out in a few months?
Sleeving is replacing your existing sleeves to iron. Ours right now is FRM and that does not work with forged pistons. Boring only should be done if theres damage done. and for an N/a Setup i would say a USDM 97-01 bottom end is better becuase its open deck. But then again if im not mistaken the 97-01 JDM motors are also open deck?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22NLINE4 »</TD></TR><TR><TD CLASS="quote">
Which block is stronger for the NA application and longevity? JDM or USDM? So if I sleeve the block do I have to bore it out as well? Someone told me that if I don't bore out the block and just sleeve then my motor will go out in a few months?</TD></TR></TABLE>
they are the same as stated before.
you're gonna have to put some oem pistons in there unless you sleeve it.
if you have someone sleeve it for you like golden eagle or darton then
all you'll have to do is slap the forged pistons in.
you should study up on sleeving your motor
give Earl or Goldeneaglemfg a pm, they can lead you in the right direction
and even build up the whole block for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">
and even build up the whole block for you. </TD></TR></TABLE>
Thank you...actually the shop is sending my block to goldeneagle for the sleeving...
