disabling abs ?
Old Sep 1, 2004 | 01:09 PM
vti444's Avatar
Default disabling abs ?
on ek4
is it possible to disengage it temporarily and easily ?
Old Sep 4, 2004 | 08:54 AM
vti444's Avatar
wanna know
Old Sep 4, 2004 | 09:36 AM
Hawkze_2.3's Avatar
Default Re: disabling abs ? (vti444)
Why not just pull the fuse?
Old Sep 4, 2004 | 10:26 AM
user 9782082308's Avatar
Default Re: disabling abs ? (Hawkze_2.3)
Pull the e-brake up just enough so that the light comes on. After driving like that for a minute the abs will disengage and the abs light will come on.
Old Sep 4, 2004 | 11:16 AM
vti444's Avatar
tried the handbrake thing and didnt work, wheres the abs fuse ?
Old Sep 4, 2004 | 03:03 PM
Mikizzle's Avatar
after disabling the abs, is there a way to bring it back?
Old Sep 5, 2004 | 04:27 AM
vti444's Avatar
Default Re: (grn4drgsr)
not tried it yet but readin through the threads you just switch ya car of and back on again
CarsCarsCars's Avatar
if you disable it by pulling the fuse just put the fuse back in. If that doesn't do it then you can recet the ECU, but putting the fuse back in and restarting the car should do it.
Old Sep 5, 2004 | 10:54 AM
Newman's Avatar
New User
Default Re: (CarsCarsCars)
If you just remove the fuse, you have the ABS light staying on your cluster all the time. The best way to disable it.... find the ABS computer and unplug the 2 or 3 plugs going into it. That way, no ABS and no ABS CEL.
Old Sep 5, 2004 | 12:04 PM
vti444's Avatar
Default Re: (Newman)
how do you get rid of abs light if it stays on ?
Old Sep 5, 2004 | 12:26 PM
Newman's Avatar
New User
Default Re: (vti444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 &raquo;</TD></TR><TR><TD CLASS="quote">how do you get rid of abs light if it stays on ?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">If you just remove the fuse, you have the ABS light staying on your cluster all the time. The best way to disable it.... find the ABS computer and unplug the 2 or 3 plugs going into it. That way, no ABS and no ABS CEL.</TD></TR></TABLE>
Unplug the ABS computer
Old Sep 5, 2004 | 02:26 PM
vti444's Avatar
what i meant is once i want to put abs back
Old Sep 5, 2004 | 06:51 PM
black2001ITR's Avatar
does disabling abs using any of the above methods cause any problems with the abs unit?
or is it perfectly safe for the car???
Old Sep 6, 2004 | 12:44 PM
vti444's Avatar
plugged abs fuse back in and no abs light, works perfectly fine as i found out with encounter with ek9 today
Whatislove
Honda Civic (2001 - 2005)
Aug 29, 2009 08:35 PM
cslegacy
Sep 11, 2007 03:36 AM
m1northreat
Honda S2000
Mar 12, 2007 10:08 PM
ArchAngel Sabastian
Jan 20, 2003 04:49 PM
