Help Me Please! Header Stud stripped. Now what?
Old Sep 1, 2004 | 11:39 AM
asubennett's Avatar
Default Help Me Please! Header Stud stripped. Now what?
Lower left stud (facing the motor) on a PR-3 head will not thread in.
The size of the bolt is a M8 1.25.
Any recommendatiosn on where to buy an "oversized stud? Or do I need to drill it out and make new threads?
If this is the case do I run any risk of hitting an oil or coolant passage? Also what size would you recommend I drill the new hole out to. I am lost.
THanks for the help. Jason
Old Sep 1, 2004 | 12:18 PM
JimBlake's Avatar
Default Re: Help Me Please! Header Stud stripped. Now what? (asubennett)
HeliCoil?
or the other thing, what are they called, TimeSerts??
Old Sep 1, 2004 | 12:57 PM
StyleTEG's Avatar
I have no direct experiance, but I have herd its risky to drill out the hole because of nearby coolant passages.
Old Sep 1, 2004 | 03:42 PM
asubennett's Avatar
Default Re: Help Me Please! Header Stud stripped. Now what? (StyleTEG)
I have heard of these heli-coil things before. Is this somethig you can readily pick up at a hardward store? Where could one obtain a heli coil?
Also I am not familiar with a time sert. What is that? Which more readily available and effective?
Old Sep 1, 2004 | 04:03 PM
AngryTroll's Avatar
A Heli-Coil takes a little practice and the kit will cost about $30, just for one size.
You could always drill and tap a larger size—take your choice: 10X1.25, 10X1.50, 3/8X16, 3/8X24.
Old Sep 1, 2004 | 04:17 PM
asubennett's Avatar
Default Re: Help Me Please! Header Stud stripped. Now what? (AngryTroll)
I think drilling and tapping would be the easist thing to do.
But... Will I be clear of any oil/coolant passages if I take it up one size?
M10 1.25 seems to be pretty big. Is 3/8 16 bigger or smaller than that?
Old Sep 1, 2004 | 08:08 PM
asubennett's Avatar
Need more help please.
Old Sep 1, 2004 | 08:16 PM
AngryTroll's Avatar
3/8" X 16 is a little smaller than the 10mm stud.
Old Sep 1, 2004 | 09:09 PM
maxrpm's Avatar
i had the same problem and took it to a machine to helicoil it for 20 bucks.
Old Sep 2, 2004 | 01:54 PM
asubennett's Avatar
Default Re: Help Me Please! Header Stud stripped. Now what? (maxrpm)
Thanks for all the help guys! I appreciate it.
I ended up tapping the head manually with a 3/8 16 tap. USed a 3/8 16 stud and it seems to have taken care of the problem. Now every time I take the damn header off I will be doing the old 12,12, 12, 12, 12, 12, damn umm, crap, oh yeah 9/16.
Myechtatel
Jul 6, 2013 05:15 PM
Beatkidd
Dec 28, 2003 10:07 PM
hondapro_2005
Oct 13, 2003 08:25 PM
H22ek4
Jul 8, 2003 03:45 PM
