N/A LS Setup
Old Sep 1, 2004 | 11:11 AM
hybrid_vtec's Avatar
Default N/A LS Setup
I am finished with my N/A LS and will soon be off to the dyno to see what she pulls! Hoping for 180+ at the wheels, doubt it but we will see!
EG Civic HB
B18A Block/ B18B Head
-Mild PnP
-Crower 404 w/ JG Cam Gears
-Crower Valvesprings
-Ferrea SS Valves
-Cometic Head Gasket
-Skunk2 Mani
-64mm TB
-Modified Iceman intake
-JDM ITR 4-1 header w/ 2.5" collector
-No Cat
-2.5" custom piping and exhaust
-P30 B16 Pistons
-Stock Rods
-GSR Tranny w/ LSD
-Exedy Flywheel
-Clutch Specialties 6-puck clutch
-H22 injectors
-Walboro 255lph fuel pump
-SAFC2
-Chipped P75
Give me some feedback and let me know what you guys think!
Old Sep 1, 2004 | 11:39 AM
JL's Avatar
JL
Default Re: N/A LS Setup (hybrid_vtec)
nice setup! definately looking forward to see "what could have been"
Old Sep 1, 2004 | 11:54 AM
chad174's Avatar
Default Re: N/A LS Setup (JL)
Good luck! Let us knowwhat she puts down, and, more importantly, how it feels.
Old Sep 1, 2004 | 07:13 PM
Darkane's Avatar
Nice work. Looks good Let us know about the Dyno. Hopefully those cams can make power to 8
Old Sep 1, 2004 | 10:43 PM
volcom40street's Avatar
Almost same setup Im going with. Please put up graph when dynoed.
Old Sep 2, 2004 | 05:37 AM
Default Re: N/A LS Setup (volcom40street)
I plan to but its going to be about another week or two before I can get to the dyno! I am looking forward to see what she does!
I am hoping for for something in the 180whp range, but its going to take some tuning!
Old Sep 3, 2004 | 05:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom40street &raquo;</TD></TR><TR><TD CLASS="quote">Almost same setup Im going with. Please put up graph when dynoed.</TD></TR></TABLE>
Whats your setup!
Old Sep 3, 2004 | 08:59 AM
non-VTEC's Avatar
Default Re: N/A LS Setup (Darkane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane &raquo;</TD></TR><TR><TD CLASS="quote">Nice work. Looks good Let us know about the Dyno. Hopefully those cams can make power to 8 </TD></TR></TABLE>
they will make power to 8k no prob..........sounds like a nice setup...get it tuned though....dont drive around with it untuned very long.
Old Sep 3, 2004 | 09:06 AM
Default Re: N/A LS Setup (non-VTEC)
Yea I need to get it tuned but I have to find a dyno here in San Diego! I know there is some here but Im new to the area and dont know where everything is! If anyone has any suggestions for good shops with dynos!
Also I still have a problem with my Fuel Pressure being too high(50psi), and my B&M wont adjust it down anymore!
Old Sep 3, 2004 | 09:10 AM
non-VTEC's Avatar
you need to modify the FPR to relive some fuel pressure from the walboro fuel pump.
if you search around you will find some more infor about it....
Old Sep 3, 2004 | 09:12 AM
from the endyne website!
Yep, I have already done it and it didnt work!
Old Sep 3, 2004 | 09:13 AM
non-VTEC's Avatar
it should work.....maybe you didnt drill the hole big enough?
Old Sep 3, 2004 | 09:30 AM
it said .035" and thats what I did
Old Sep 3, 2004 | 09:47 AM
743power's Avatar
That setup is definitely good for 180. Hurry up and get that bitch dynoed.
Old Sep 3, 2004 | 09:52 AM
non-VTEC's Avatar
then try .040 or .045 until it drops some fuel pressure.........
honestly i dont think you will need that walboro fuel pump. the stock one provides plenty of fuel even with those larger injectors.
Old Sep 3, 2004 | 10:16 PM
AllMotorDA9's Avatar
all motor LS
keep us informed on the dyno
Old Sep 4, 2004 | 03:39 AM
Greenery18's Avatar
Default Re: N/A LS Setup (OneSlowDA)
I have some b16 p30's in my ls, I'm interested to see what you put down. Your setup looks well matched up, and tuning should help you out a bit. How is the idle right now with those 404's?
Old Sep 4, 2004 | 09:43 PM
Default Re: N/A LS Setup (Greenery18)
Idles pretty rough until I set idle at 1000rpms. I hope it makes 180whp we will see. Someone tell me a good dyno to go to here in San Diego(New to Area)
As far as the FPR goes Im gonna try .045" and see what happens! My stock fuel pump is for a D16Z6(92 Civic HB Si); do you think it will support my setup or should I stay w/ the 255lph walboro unit?
Old Sep 6, 2004 | 10:59 PM
JDimageEk's Avatar
very nice setup...im shooting for N/A LS as well , so im looking forward to your results man.
Old Sep 7, 2004 | 08:16 AM
chad174's Avatar
Default Re: N/A LS Setup (JDimageEk)
a stock fuel pump is fine for your setup. good luck at the dyno.
Old Sep 7, 2004 | 09:22 AM
Drag_On's Avatar
That looks like a 165-170 whp set up to me..
But great build none the less. Someone help this man out finding a good dyno in SD.
Nice set up bro !!
Old Sep 7, 2004 | 09:52 AM
Default Re: (Drag_On)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On &raquo;</TD></TR><TR><TD CLASS="quote">That looks like a 165-170 whp set up to me..
Nice set up bro !!</TD></TR></TABLE>
Thanx! Yea I need to know what shops in SD have good techs for dyno tuning! Any recommendations? Looking for somewhere with a dynojet dyno!
Old Sep 8, 2004 | 10:09 AM
Default Re: (hybrid_vtec)
bump for Dynos in San Diego, CA
Old Sep 9, 2004 | 12:50 PM
allmotorej8's Avatar
with the pistons it should easilly achieve 175-185 with the head work and all the things he has done to it, styleteg made 164whp with simple bolt on no headwork or bottom block work!!
to hybrid_vtec , i wanna see those dyno's sheet hitting 175+!!
good set-up! keep us updated!
-i sugest u get a fpr set it at around 41-44 and ur idle should be just fine at around 900rpm's!!
Old Sep 9, 2004 | 04:54 PM
nonvtecallmotor's Avatar
Default Re: (aLLmTreK)
Good luck with the set up. I had a simular set up make 178hp/ 138tq.
