a few other questions about gsr engine into a 95'
i heard that my stock exhaust system won't bolt right onto the gsr header? BUT if i use the LS header, it should bolt right on...is this true??
also i know that all the plugs from the gsr engine harness should plug right into the engine bay harness...but does this go the same with the JDM gsr motor?? i don't know if the USDM motor and the JDM is the same or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo »</TD></TR><TR><TD CLASS="quote">i heard that my stock exhaust system won't bolt right onto the gsr header? BUT if i use the LS header, it should bolt right on...is this true??
You need to use the factory harness for the vehicle and then just add the Vtec solenoid, knock sensor, and vtec pressure to the correct pin locations. Do Not use the JDM harness, it will not work, but you can take all of the vtec wiring from the jdm harness and use it!
</TD></TR></TABLE>You need to use the factory harness for the vehicle and then just add the Vtec solenoid, knock sensor, and vtec pressure to the correct pin locations. Do Not use the JDM harness, it will not work, but you can take all of the vtec wiring from the jdm harness and use it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo »</TD></TR><TR><TD CLASS="quote">so the JDM engine harness won't plug right into my civic harness???</TD></TR></TABLE>
you cannot use jdm harness as everything is opposite. use your stock harness and add the vtec wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">you cannot use jdm harness as everything is opposite. use your stock harness and add the vtec wires</TD></TR></TABLE>
use the stock civic engine harness and plug it into the gsr engine?
use the stock civic engine harness and plug it into the gsr engine?</TD></TR></TABLE>
correct...
also, don't forget add the other wires that 89cvchb mentioned.
correct...
dadsvtechonda
Jun 22, 2007 12:02 AM
JDubya
Sep 1, 2003 12:03 PM
KevronsEG
May 31, 2003 07:13 AM
