insrument light/parking light fuse keeps blowing
Old Aug 31, 2004 | 07:46 PM
t0ekn3e's Avatar
Default insrument light/parking light fuse keeps blowing
recently my fuse blew and i have tried replaceing it with diffrent fuses and they all blew i check the wires the best i could and i dont see a loose wire an idea what might be the problem any help would be great thanks in advance
Old Aug 31, 2004 | 08:38 PM
BatuKing's Avatar
Default Re: insrument light/parking light fuse keeps blowing (t0ekn3e)
If it blew you have a short to ground somewhere. Now do you have an alarm or aftermarket radio? check the red/black wire behind the radio its the same as the cluster fuse.
but get a wiring diagram and check it out.
Old Aug 31, 2004 | 09:17 PM
nocturnaldragon's Avatar
Check the harness going to the lights. There might be a spot where the wire is rubbing aginst the frame somewhere and is shorting out there.
Old Aug 31, 2004 | 11:00 PM
t0ekn3e's Avatar
ok ill check in the morning and have an update thanks alot
ajason24
36
Jun 4, 2009 05:14 PM
devin_hoang
Nov 22, 2008 02:27 AM
RHGSR01
Oct 30, 2004 02:12 PM
tgctruly
Oct 17, 2004 08:51 PM
LOWLIFEHATCH
Sep 1, 2004 06:48 AM
