HELP!!! Swap from hell...D series swappers plz
Car-1988 CRX
Motor-D16y7
Problem- Crank Pully
I am putting everything back together on the car and it's time to put the crank pully on(the D15 pully.) I put the pully over the snout of the crankshaft and it won't go on!!! The hole in the pully is too small.
I would use the D16 pully, but it has three ridges in it for the alternator belt (D15 has only 2) and the diamater is different. Do I need an EF Si pully? What gives?
Thanks in advance.
Motor-D16y7
I am putting everything back together on the car and it's time to put the crank pully on(the D15 pully.) I put the pully over the snout of the crankshaft and it won't go on!!! The hole in the pully is too small.I would use the D16 pully, but it has three ridges in it for the alternator belt (D15 has only 2) and the diamater is different. Do I need an EF Si pully? What gives?
Thanks in advance.
DXDOHCVTEC
Sep 1, 2003 12:06 AM
