91 teg sunroof on my REX (non-functional)
I had some pos aftermarket sunroof on my car when I bought I hated it from the start because glass was missing. Ohwell went to the Jyard managed to pick out a nice looking pos aftermarket sunroof which lasted me 2months before thermoshock(plus a screw driver) blew it. I had an entire 91 teg sunroof assembly laying around but I knew it wouldnt fit so I didnt bother with the assembly I removed the glass and went to work. My hole for the aftermarket sunroof was a bit wider than I needed it to be for my teg glass meh so what I figured since the teg roof had a metal backing plate I could fab up some sort of sheet metal cover for that. I cut the hole to shape then squeezed it in fabed up a few support brackets bolted them on and used some black gasket maker around the inside of it. heres the final product...
