Few quick questions again.....
I had a few questions cause I'm in the process of shopping for parts for my new project car.
1.)Is it possible to use 94-2001 shocks on a 90-93 integra with no modification?
2.)Which distributors can I use on my 92 integra? Any OBD1 distributor?
3.)I bought the car with a stripped oil drain plug. What can I do to fix this without having to replace the oil pan itself?
I'll ask more as I think of them... thanks for your time guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B18ABorC »</TD></TR><TR><TD CLASS="quote">I had a few questions cause I'm in the process of shopping for parts for my new project car.
I have personally seen the latter 2 questions answered on here before. Don't remeber, though.
SEARCH! https://honda-tech.com/zerosearch
</TD></TR></TABLE>I have personally seen the latter 2 questions answered on here before. Don't remeber, though.
I'm almost positive that the 90-93 shocks don't have a "fork" on the bottom that bolts to the control arm. So the 94+ shocks won't work. I'm talking about the rear. I'm pretty sure the fronts will work.
Just make sure you have a Vtec distributor with a Vtec motor and non-vtec one for a non-vtec one respectively. Not even sure if they made GSR's in 1992.
Buy a tap and die set and you can re-tap the hole. Or you can borrow someone's set. Very easy.
1. shocks do not work
2. non-vtec distributor. **But make sure because 92 was the first year of the GSR. Make sure you know which yours is. Either should be a b18 or b17 on the block stamp.
3. shamoo answered this one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">1.)Is it possible to use 94-2001 shocks on a 90-93 integra with no modification?
Buy a tap and die set and you can re-tap the hole. Or you can borrow someone's set. Very easy.</TD></TR></TABLE>
<FONT COLOR="royalblue"> 92-93 GS-R w/ a B17a1! I think he has a B18a, since his handle is BuildB18.
</FONT>
</FONT>
You got it backwards, sorta: The rear shocks fit perfectly with no modifications, while the front shocks will fit if you buy front forks from any EG or DC.
Check out the hybrid suspension article at http://www.g2ic.com, that is a good resource for g2 info.
