reinstalling timing belt Q?
Old Aug 31, 2004 | 04:19 PM
R.S.'s Avatar
Default reinstalling timing belt Q?
in order to reinstall the timing belt onto the cam gears i need to remove the crank pulley correct (i only slipped the timing belt off the cam gears to remove the head)? is the only way the way it says in the helms?
b/c i need to adj the timeing belt tensor.
so i need to get that big 50mm hex pulley holder tool, right, that seems like it would be the best/easiest way?
i search a lil and found sum info but need a lil more detailed info.
Old Aug 31, 2004 | 04:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: reinstalling timing belt Q? (R-Spec)
You should be able to get it on if you loosen the tensioner pulley. After you get it onto the cam gears (make sure the crank pulley and cam gears are all lined up correctly), then tension the belt as indicated in the Helm's manual.
Old Aug 31, 2004 | 04:55 PM
R.S.'s Avatar
Default Re: reinstalling timing belt Q? (PatrickGSR94)
don't i need to remove the crank pulley to get at the tensioner pulley?
Old Aug 31, 2004 | 05:16 PM
Community Builder
Actually there is a hole in the lower plastic cover allowing access to the tensioner pulley bolt. Loosen that, slip the belt on (again double and triple check to make sure everything is still lined up) and then tighten the bolt, then follow the specified tensioning procedure.
Old Aug 31, 2004 | 07:17 PM
R.S.'s Avatar
aight cool thanks, i'll try it out tomarow after school.
so as long as the crank is at tdc and the cams are at tdc (held by the 5mm pin punch)i can release tension on the timing belt and move it into place, corect?
Old Sep 1, 2004 | 12:22 PM
R.S.'s Avatar
i put it on tdc but when ever i try to get the timing belt on the cam gears the cranpulley moves off tdc...
edit: used this method: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "ggrrssyydik" &raquo;</TD></TR><TR><TD CLASS="quote">the getto way, line it up on top dead, then as you install the cam, come in at a angle so you could slip the belt on to the gears, as you tighten the cam caps its gonna pull the belt tighter, then aftereverything is installed juts loosen the tensioner bolt then turn the motor to put set tension, and tighten the tensioner. no need to remove the lower pulley and cover.</TD></TR></TABLE>
got it from a member on jdmi
Modified by R-Spec at 4:32 PM 9/1/2004
austinramsay
Jul 5, 2014 12:42 PM
wk9k
Mar 13, 2012 05:45 PM
god.loves.ugly
Jan 18, 2007 03:44 PM
teddy_dc2
Jul 6, 2006 09:15 AM
gavhowe
May 7, 2003 08:45 AM
