Universal IC piping kit. Where to buy and what bends?
Guest
Posts: n/a
did a search and turned up nothing
Where do you buy pipes on jc whitney or anywhere else for that mater.
Also what bends would you recommend, I know you dont know my setup and that makes it difficult. Do your best though. Thanks
Nobody can tell you exactly what you need. Every setup is different. Every install CAN be different (different angles, creative routing, etc). Just try to visualize how you want the pipes to go and order a couple extras in case you mess up. You can always sell them in the Classifieds section.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">Hands down.
https://honda-tech.com/zerothread?id=873412</TD></TR></TABLE>
thats who im buying my piping and flanges from.
go to http://www.summitracing.com
then go to summit parts, and then to exhaust.
buy their Jpipes. usualy u need 3-5 pipes. order the diameter u want and wait for them to come in the mail.
I got all mine from jc whitney.. You dont need to weld them, you can just use connectors to make all the pipes meet..
Guest
Posts: n/a
ok lets try this again. thanks for the responses so far but this is whats really important to me.
Thanks again guys
Which bends to buy and how many?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_joe »</TD></TR><TR><TD CLASS="quote">Nobody can tell you exactly what you need. Every setup is different. Every install CAN be different (different angles, creative routing, etc). Just try to visualize how you want the pipes to go and order a couple extras in case you mess up. You can always sell them in the Classifieds section. </TD></TR></TABLE>
thanks joe but I have no idea how Im gonna run my piping. just seeing if there was possibly an easy way to find out
Thanks again guys
Placement of the turbo/manifold/FMIC/bumper support/ABS/Air Conditioner all factor into where you route your IC piping. It's not "universal". It's application specific.
Remove the front bumper and visualize where the piping needs to go. Count the bends and order them. You're making it more difficult than it really needs to be. We're not here to feed you with a silver spoon...put some elbow grease into your work!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">Placement of the turbo/manifold/FMIC/bumper support/ABS/Air Conditioner all factor into where you route your IC piping. It's not "universal". It's application specific.
uhg. aight more importantly how do I mount the damn ic?
Im such a noob
</TD></TR></TABLE>uhg. aight more importantly how do I mount the damn ic?
Im such a noob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetech »</TD></TR><TR><TD CLASS="quote">
Im such a noob</TD></TR></TABLE>
lots of duct tape
Im such a noob</TD></TR></TABLE>lots of duct tape
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit »</TD></TR><TR><TD CLASS="quote">
lots of duct tape
i used scotch tape
lots of duct tape
</TD></TR></TABLE>i used scotch tape
Wow.
Talk about being prepared!
Weld tabs to the IC. Drill holes in the bumper support and tabs. Bolt it up. Otherwise, coat hangers work too.
Once you get the two in/outlet piping hooked up, the IC should be snug in place.
Im such a noob</TD></TR></TABLE>Wow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlendedEJ »</TD></TR><TR><TD CLASS="quote">
i used scotch tape</TD></TR></TABLE>
I thought i was alone on that one...
Took me 4 U-Bends for my whole intercooler pipings... Get 5 if your a noob..
Just in case you messed up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetech »</TD></TR><TR><TD CLASS="quote">did a search and turned up nothing
look in yellow page in ur area stuffs, and for what bend...hte most affordable and good performance bend is mandrel bend...from muffler shop...so....you have to pick ur setup
but mandrel bend (smooth bend at corner) is the way to go
</TD></TR></TABLE>look in yellow page in ur area stuffs, and for what bend...hte most affordable and good performance bend is mandrel bend...from muffler shop...so....you have to pick ur setup
