'93 Accord 10th Anniv. Automatic tranny skips 2nd gear, and starts off in 3rd sometimes. HELP!!!
Old Aug 31, 2004 | 02:19 PM
grngrcrygettr's Avatar
Default '93 Accord 10th Anniv. Automatic tranny skips 2nd gear, and starts off in 3rd sometimes. HELP!!!
I read another post similar to this. My car starts off in 3rd and shifts to 4th after about 50 mph. When I shift it to 1, it starts off in 1st gear, then when I shift it to 2, it jumps to 3rd, only until I hit 40 is where it jumps back to 2nd. I heard that it could be a fried TCM...I NEED HELP.
Old Aug 31, 2004 | 04:55 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: '93 Accord 10th Anniv. Automatic tranny skips 2nd gear, and starts off in 3rd sometimes. HELP!
why would you be shifting if it was automatic?
Old Aug 31, 2004 | 07:28 PM
cmrvi1's Avatar
As many of you are aware, early 90's Accords regularly have transmission shifting problems (eg. S light flashing or on steady, D4 light flashing, trans takes off in 2nd gear). The most common cause of this is a burnt out TCM.
I have been rebuilding these computers for quite some time now and have some in stock ready for shipping, or I can rebuild yours.
For pricing, or more information, please email me at: cmrvi1@yahoo.com
Below is some info on how to check for codes, TCM location, and most IMPORTANTLY, how to check your TCM.
Behind the right hand corner of the dash on the passenger's side (just below the glove compartment, or sometimes stuffed behind the kick panel) you will find 2 connectors taped to the wire harness with blue tape ( unless someone previously removed the tape). One is a three wire connector (data link connector) the other is a two wire connector. By jumping the two wires on this connector, you check for engine and transmission codes.
With the ignition switch off, connect the two wires together. Have a pen and paper handy. Turn the ignition switch on. The S light (or D4 light if your car doesn't have the S light) should start to flash a code. Might be a combination of long and short flashes. A long flash stands for 10, and short flashes are 1. For example, if the light blinks: long-short-short-short, then that is a code 13. When you find out what code it is, post it and I can tell you what is going on. BTW, 90-93 Accords have a bad habit of burning out the trans computers. So sometimes you won't get a code. The light will just stay on steady when you jump the connector.
If the light doesn't blink when you jump the connector, then your TCM (transmission control module) might be bad.
To verify this, remove the TCM ( it's located under the rug on the passenger side) bolted to the firewall. You will find two modules bolted to one bracket. The TCM is the smaller of the two, on the right.
To remove it, you'll need to remove the 4 bolts securing the bracket. Then, unplug both computer modules, and gently remove the bracket.
Next, unbolt the TCM from the bracket.
Remove the four screws that hold on the cover.
Look at the board carefully. If it is bad, you will find a burnt out resistor and a leaking capacitor. Again, LOOK CAREFULLY. Yours might not be as bad as the one in the picture, and only one of the resistors will overheat and turn slightly brown. If this is the case, I can rebuild it for you, or sell you a rebuilt one.
Email at cmrvi1@yahoo.com for more details.
This is the TCM
With the connector pointing down, the bad spot will be in the lower right corner
This is what the damaged part looks like up close
Old Aug 31, 2004 | 10:18 PM
In order to start off in 1st I have to shift it to D1, otherwise it starts off in 3rd and sometimes 2nd.
doncello
Oct 29, 2015 10:24 AM
Harvz
Jan 4, 2005 01:03 PM
supnhere
Nov 2, 2004 06:30 PM
