ITR Ride Height vs. Other Integra's Ride Heights
Old Aug 31, 2004 | 01:04 PM
Curt941's Avatar
Default ITR Ride Height vs. Other Integra's Ride Heights
The reason i ask this question is because of lowering springs. I'm thinking of ordering some Tein Springs, and they say they lower 2.5" in front and 1.7" in rear, this is probably for regular non Type R integra's, so i'm trying to figure out how much they would lower my car from stock ? Thanks.
Old Aug 31, 2004 | 01:07 PM
cheezthis's Avatar
Default Re: ITR Ride Height vs. Other Integra's Ride Heights (Curt941)
Search for pictures of other integras, r or non, w/those springs and you will find your answer.
Old Aug 31, 2004 | 01:09 PM
Curt941's Avatar
Default Re: ITR Ride Height vs. Other Integra's Ride Heights (cheezthis)
just searched, and couldn't find any pics...all i need to know is how much lower the ITR is than other Integra's, that's all.
And yes, i searched for the answer to the question...I believe i saw someone post that it was about 1inch lower stock, but i wanted to confirm, that's all.
Old Aug 31, 2004 | 01:19 PM
Opie's Avatar
AFAIK the ITR is .75 inches lower than other Integra models...
Old Aug 31, 2004 | 01:20 PM
B2FiNiTY's Avatar
Default Re: (opie)
Actually .5 inch according to my owner's manual.
Old Aug 31, 2004 | 01:22 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
15mm lower.
Old Aug 31, 2004 | 01:56 PM
Curt941's Avatar
Default Re: (Rguy)
thanks guys, you were a big help.
Old Aug 31, 2004 | 02:04 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (Curt941)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys, you were a big help. </TD></TR></TABLE>
Even though you got three different answers? LOL...
Old Aug 31, 2004 | 02:10 PM
Curt941's Avatar
Default Re: (George Knighton)
well, two of them were close to 1/2 an inch, so that's good enough
Old Aug 31, 2004 | 02:12 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">15mm lower.</TD></TR></TABLE>
This one is the correct answer. (That's about 0.6 inch.)
Old Aug 31, 2004 | 02:44 PM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 31, 2004 | 03:30 PM
Curt941's Avatar
Default Re: (Rguy)
thanks, so if a spring meant to lower a regular Integra was 2.5in lower, theoretically it would lower an ITR 1.9in from stock?
Old Aug 31, 2004 | 03:41 PM
B_CRUZ!'s Avatar
NO OE R springs are shorter than NON R springs. so if the lowering spring that you are purchasing is going to lower a RS/LS/GS/GSR 2.5" it would lower a R 2.5" also.
Old Aug 31, 2004 | 03:47 PM
Curt941's Avatar
Default Re: (b cruz)
My thought was this:
The OE Non R spring is Xinches long
The 2.5inch lower spring is X-2.5" long
and the OE R spring is X-.6" long...
Thus, the difference between the Lowering spring and OE R spring is (X-.6)-(X-2.5)=1.9??? Is this logic correct?
Old Aug 31, 2004 | 03:50 PM
B_CRUZ!'s Avatar
yes.. what I meant was if you buy 2.5" lower springs and put them on a R, those same springs on a LS would be the same height as the R.
just search for the spring that you are about to purchase and see if others have it and posted it up..
Old Aug 31, 2004 | 05:22 PM
xmilanoredsix's Avatar
Have the tein springs installed on my car.
To be completely honest if you really dont know type R's very good you probably
wouldnt be able to tell its lowered. Probably lowered it about an inch total.
And your theory about it lowering a regular integra lower then a type r is correct.
PM me if you have any other questions.
Old Aug 31, 2004 | 05:54 PM
mugenracer's Avatar
The ITR is 15mm lower than other integras, so if you buy springs that lower a GSR 25mm (1") then they will only lower an ITR 10mm more than it currently is. the opposite applies if you put, say 35mm lowering springs meant for an ITR into a GSR, then they will lower it 15+35mm=50mm, as happened to me with my last teg, i forgot that the ITR was lower and ended up having to change the springs for regular integra ones as it was too low on the ITR springs.
integrawow
Nov 27, 2008 09:16 PM
bikerballrEM2
Mar 31, 2008 08:52 PM
CerealWars
Suspension & Brakes
16
Feb 6, 2005 06:29 AM
ITR0145
Apr 6, 2002 11:00 PM
Just2Fast
Feb 2, 2002 06:57 PM
