CRX negative camber kits
Old Aug 31, 2004 | 12:16 PM
rexnst9's Avatar
Default CRX negative camber kits
Just looking for a few manufacture names of who makes these kits. I am aware of Vision are there any others? I did a search and came up with a few different companies but did not see any that refered to a negative kit. Any sugestions would be great.
Old Aug 31, 2004 | 12:35 PM
manson's Avatar
Default Re: CRX negative camber kits (Bruce Ward)
ummm...
adjustable kits will allow you to adjust camber to make them more negative or more positive.
i have an SPC kit... it replaces the upper balljoint instead of the ingalls style kit.
Old Aug 31, 2004 | 12:45 PM
rexnst9's Avatar
Default Re: CRX negative camber kits (manson)
Thanks dude I appreciate the response. I have one of the those ingalls kits on the car now. Problem is I swapped over the front brakes from a 96 Integra and I have still to much positive camber. I need a kit like this kit by Vision which will give me enough negative camber adjustment to put the car into spec. I have heard there is other companies making these kits I guess they are common with people running track cars.
Old Aug 31, 2004 | 01:31 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Ward &raquo;</TD></TR><TR><TD CLASS="quote">Problem is I swapped over the front brakes from a 96 Integra and I have still to much positive camber.</TD></TR></TABLE>
How many degrees total do you need to adjust?
Old Sep 15, 2004 | 03:04 PM
Garrett's Avatar
Default Re: CRX negative camber kits (travis)
I made the same swap, and WE need about 2-3 degrees
7panget
Oct 4, 2007 03:34 PM
QuickRexSi21
Sep 21, 2005 09:36 PM
E-lude78
11
Oct 20, 2003 07:21 PM
ESCALVANTE
Jan 31, 2002 10:36 AM
