cold start doesnt work?
waht you guysi blew my motor so i swaped a single cam in, everything works fine but when the cars cold when it turns on it just idles at 500, my other motor idled at 1 to 3 rpms normally, what do i do? also my car will idle normally at 800 rpms and when i turn on the ac it wil drop to 400 and almost bog out while driving, i dont want to up the vavle cuz then it will idle at 1 so what should i do?
every honda bogs when the a/c is on.
don't worry if your car is idling at 500 because first of all the gauges aren't that acurate, and second.. well it just doesn't matter if its that little below 800
no, a loose belt wouldn't cause it to die.
go get some "marvel's mystery oil" and use some of that (not in the fuel tank, but pour it directly into your motor). se if that helps any.
Bigmman
Sep 24, 2008 01:38 PM
