ITR Front Sway Bar Install On GS 4Dr
I've understood from previous posts that the ITR Front Sway Bar will in fact bolt right on to any DC2 Chassis. Can anybody confirm this from their own applications. For the rear sway bar i understand that i can't so i plan on purchasing the Comptech Rear Sway Bar Tie Bar Combination.....Please can anybody comfirm this....
you can use the oem ITR rear sway bar with a BSQ mounting kit...otherwise with out the kit you might tear out the subframe..... get the itr bar at http://www.ahmotors.com and there is a member on here named BSQ that makes the kit whole thing can be bought for about $125... the front sway bar is the same size i believe as the ITR
do a search for BSQ
do a search for BSQ
onsetofpurity
Jan 9, 2008 06:00 AM
dgdarien
10
Mar 30, 2003 01:09 PM
mamaboy
Nov 17, 2001 06:49 AM
