Can I get some opinions on wheels that I want to purchase? Other stuff too
Old Aug 31, 2004 | 09:48 AM
phanatic's Avatar
Default Can I get some opinions on wheels that I want to purchase? Other stuff too
I have an all black 95 civic ex, and I want to go with a black and yellow appearance. I want all the vents and some other stuff in the inside painted yellow. How should I go about doing this?
These are the wheels I was checking out. Is this a good company? Can I put 17 inch wheels on a civic?
Thoughts or suggestions are welcome
edit:Suggestion noted!! Changed wheel to something else. If you have thoughts on wheels, hook me up.
P.s. How big does honda make their wheels?
Modified by phanatic at 11:03 AM 8/31/2004
Old Aug 31, 2004 | 09:54 AM
screech's Avatar
Default Re: Can I get some opinions on wheels that I want to purchase? Other stuff too (phanatic)
how bout you just delete your post and try again with some rims that arent FUGLY AS $HIT. what im tryin to say is that no one will like those rims as they are hidious IMO.
Old Aug 31, 2004 | 09:57 AM
Vero's Avatar
If you REALLY like yellow that much.
17"s will fit on a civic, but lowering it will be advised. Look at 16"s for a better look. And in my personal opinion along with just shy of all of honda-tech, look at different wheels too, those are just horribly ugly. But if you like them, its your car.
as far as painting the interior, some of the vents can be removed, you will have to look at a diagram for your car. Since the vents are hard plastic, it would be ok to use Krylon's Fusion brand spray paint which is designed for plastics.
But the ideal way would be to use Vynil Spray Dye. It will bond better, last longer, and hold the stock textures better. You can also use this on the soft plastics in the car too.
Tape everything off extremely well first.
Id figure Id help you out, but I strongly suggest looking at keeping the interior the same color as well as less eye-soring wheels.
Old Aug 31, 2004 | 09:59 AM
punku10's Avatar
https://honda-tech.com/zerothread?id=594739
https://honda-tech.com/zero...age=3
https://honda-tech.com/zerothread?id=839254
check out those threads and then ask yourself if this is the correct place to be posting up something like that
Old Aug 31, 2004 | 10:01 AM
squirrel's Avatar
a lot of people are going to give you ****.
IMO, do what you want, but try to educate yourself first. Figure out what you are hoping to accomplish with this car?
oh yea, I'm pretty sure someone will chime in and tell you to go "JDM". So, I'll say it now. JDM is gay as well.
Old Aug 31, 2004 | 10:07 AM
punku10's Avatar
Default Re: Can I get some opinions on wheels that I want to purchase? Other stuff too (squirrel)
honestly its all up to you... i posted above the threads on here that people could put pictures of the nicest cars in there opinion
what you need to do is look through it figure out what kind of style you want to go for and just look for a rim that you like.
do you really want your car to look the way somebody else wants it to. i would hope not
so your best bet would be to go to the apperence cosmetic forum i konw you can't post there but just look around at some cars find some rims you like and then buy them.
Kristoff Bishop
Sep 16, 2017 12:44 AM
scootibum
Other Make Vehicles
45
Nov 1, 2010 06:37 PM
preluderemis
Nov 30, 2008 07:09 PM
Lil Azn Dave
Honda Civic (2006 - 2015)
Oct 3, 2008 05:00 AM
-RedneckDave-
Feb 26, 2004 02:35 AM
