Crankcase pressure real high - would it affect Top end performance?
Old Aug 30, 2004 | 09:29 PM
Darkane's Avatar
Default Crankcase pressure real high - would it affect Top end performance?
Like it says, My problem was I started leaking some oil from my check spout at the bottom and wondered why. Then it occured to me I got no PCV. I got a B20 with a B18 Valve cover and the B18cover('95 model) does not have one. I belive the B18 breathed through the cannister on the block but the B20 doesnt have one so I plugged the line from the IM. Any comments..?
Old Aug 31, 2004 | 06:11 PM
Seth21's Avatar
Default Re: Crankcase pressure real high - would it affect Top end performance? (Darkane)
goto theoldone.com and order the moroso breather kit $150 it'll help out alot
Seth
Old Sep 4, 2004 | 12:54 PM
Darkane's Avatar
Default Re: Crankcase pressure real high - would it affect Top end performance? (550whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 550whp &raquo;</TD></TR><TR><TD CLASS="quote">goto theoldone.com and order the moroso breather kit $150 it'll help out alot
Seth</TD></TR></TABLE>
thanks for the reply man. I checked it out. Do you know if there is any drilling involved? And.. will it work on the non-V? Im sure it will considering they have basically the same casting (blocks). thx again.
Old Sep 4, 2004 | 04:26 PM
therealpoorboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the reply man. I checked it out. Do you know if there is any drilling involved? And.. will it work on the non-V? Im sure it will considering they have basically the same casting (blocks). thx again.</TD></TR></TABLE>
no drilling involved. it will save you a bunch of time if you take the im off first though.
hasback*
Feb 15, 2007 01:30 PM
Stephdavis18
Apr 16, 2006 11:06 AM
roycivic92
Dec 29, 2004 05:57 AM
H2nr
Jan 1, 2004 02:14 PM
H23vtecEG
Dec 26, 2003 10:02 PM
