K20 Short blocks, heads and 6spd, D15 block and head, RC overbored TB
Decided not to venture into the valley of the unknown and went with a B swap instead...So.........
Have 2 K20A2 short blocks:
one in great shape; 29,000 miles... (SOLD AHNJ)
other one has a tight wrist pin or bad rod bearing...crank will not turn easy when #3 comes up on TDC (SOLD B18Flip)
One K20A2 head: (needs 1 valve, and all sensors--stole the valve to fix a friends car, but can get it and install it)
(SOLD MARK)
One K20A3 shortblock and head out of an auto RSX $400.00 for both
One K20A2 6 speed trans... 29,000 miles (SOLD AHNJ)
D15 shortblock with 120k on it, Head has CRX Si cam with 5 angle valve job and custom port and polish,with RC Engineering overbored TB
(SOLD LOCALLY )
Also have S2000 Saner front swaybar (brand new never installed) $250.00
2 Hydro GSR stock Diffs $20.00 each (SOLD LOCALLY )
GSR gear set with syncros and bearings (SOLD LOCALLY )
Complete Hydro LS trans with cracked case(where shift stabilizer mounts to, case does not leak oil, but mount will need to be re-welded) can possibly swap with Hydro GSR case I have... (SOLD LOCALLY )
Pickup available in New/North Brunswick area
Offers will be accepted shipping is extra....will seperate for right price(s)
Trades accepted:
Short ratio B series cable trans
DC 4-2-1 header for B16A2/3
ITR or CTR cams (Honda/Acura cams only no aftermarket equivalents)
B series Valve cover (ITR prefered)
Modified by jasyatz at 12:52 AM 9/2/2004
Modified by jasyatz at 1:39 AM 9/2/2004
Modified by jasyatz at 1:36 AM 10/2/2004
Modified by jasyatz at 8:32 AM 10/11/2004
Modified by jasyatz at 8:36 AM 10/11/2004
(SOLD MARK)
(SOLD LOCALLY )
Trades accepted:
would you consider part out the K20 stuff? If so, how much would you sell the throttle body on the A2 or A3 head, and alternator? lmk I'm very interested
Thanks
Thanks
what year and model is the K20a head from? also what is included, complete top end, or just the head? internals? also I have a chipped p28 you might be interested in. LMK
matt
matt
No intake, no throttle body no alternator...Just 3 blocks, 2 heads and 1 trans
What year and model is the K20a head from? also what is included, complete top end, or just the head? internals? also I have a chipped p28 you might be interested in.
One block is from an 02..the other (with the knock) is an 03...The base head is from an 03 Automatic..Heads have all valve train and cam sprockets included, but are dis-assembled as the heads have to come apart to remove them from the blocks.. Blocks are complete with crank,pistons and oil pan installed.
All PM's replied to
Modified by jasyatz at 12:25 AM 9/10/2004
All PM's replied to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasyatz »</TD></TR><TR><TD CLASS="quote">Decided not to venture into the valley of the unknown and went with a B swap instead...So.........
Have ONE K20A2 short block:
has a tight wrist pin or bad rod bearing...crank will not turn easy when #3 comes up on TDC $300.00
D15B7 longblock with 120k on it, Head has CRX Si cam with 5 angle valve job and custom port and polish,with RC Engineering overbored TB-Quaife equipped D15 trans sold. $300.00 obo
2 Hydro GSR stock Diffs $20.00 each (one missing one bearing )
GSR gear set with syncros and bearings $50 .00 (or offer)
Complete Hydro LS trans with cracked case(where shift stabilizer mounts to, case does not leak oil, but mount will need to be re-welded) can possibly swap with Hydro GSR case I have... $50.00
Offers will be accepted shipping is extra....will seperate for right price(s) </TD></TR></TABLE>
Think of the possibilities people! For a little work you could have a 200+ hp K motor basically for a song. Or turn a mundane CX into a less mundane CX with a proven D-series, perfect for turbo applications!!!
Buy, buy, buy!!!
Anthony "Mario" Crea
Buy, buy, buy!!!
went and picked up my stuff from Jeff and Tony this past Sunday. Great guys
Thanks for the drinks for the ride home!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anjapower »</TD></TR><TR><TD CLASS="quote">went and picked up my stuff from Jeff and Tony this past Sunday. Great guys
Thanks!!! Best of luck on that buildup. Maybe you can convince a few others to buy the other K-series items and build some wicked engines!
</TD></TR></TABLE>Thanks!!! Best of luck on that buildup. Maybe you can convince a few others to buy the other K-series items and build some wicked engines!
i'll take the ls trans and the gsr gear set. email me:
steve@tech43.com
steve@tech43.com
Ahnj,
Good to meet you and your friend who's name for the life of me I can't remember.... but you are welcome..
Good luck with the buildup and glad you got home safe..
Jeff
All PM'S replied to...
Have 2 offers on the LS trans/GSR gearset and 4 "may be's" on the remaining A3 block and head but no deposits.. .. So still For Sale
Jeff
Bump! Deposit for the remaining k20a2 shortblock sent....let me know when you get back from your trip for the pickup
other one has a tight wrist pin or bad rod bearing...crank will not turn easy when #3 comes up on TDC $300.00
SOLD Locally
Trades accepted only on itmes needed below:
SOLD Locally
Ryan,
Was great to meet you, good luck with the buiild up...I'll call you if I get something you need..
Updated sold list and responded to all PM's..
Jeff
Jeff
Updated current sold list..
All Pm's replied to
K20A3 block and head the only items left..$400.00 plus shipping or pickup
Willing to trade for short ratio cable trans..
All Pm's replied to
cpt. SPocK
Oct 16, 2014 05:53 AM
cpt. SPocK
Oct 13, 2014 07:11 PM
blue96integra
Sep 13, 2012 03:01 PM
