RSX pistons in B20?
The valve pockets are cut at a different angle from the B to the K pistons...
K series valves are angled kinda like... | |
B series is more like.... \ /
K and B series compression heights are pretty similar but the K series piston does have a larger pin bore... If I remember correctly its the same pin as the H22???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis »</TD></TR><TR><TD CLASS="quote">The valve pockets are cut at a different angle from the B to the K pistons...
K and B series compression heights are pretty similar but the K series piston does have a larger pin bore... If I remember correctly its the same pin as the H22???</TD></TR></TABLE>
The k series pin is .035 larger than b series. Just ream out the b series rod to accept the k series pin. Ive never tryed it but it will work.
you can make anything work if you really want to. skunk2 tried using rsx pistons in their b series drag motor before (which included machining the valve pockets) , but the pin bosses on the rsx pistons are notoriously weak. exploding piston problems eventually claimed the engine
lsvtec2.0
Feb 21, 2007 03:27 PM
