Are all 88-91 crx si wiring harnesses the same?
Old Aug 30, 2004 | 06:55 PM
DeKaP's Avatar
Default Are all 88-91 crx si wiring harnesses the same?
someone told me they are someone told me they arent
Old Aug 31, 2004 | 08:12 AM
686_ef's Avatar
nope the 88-89 harness is different than the 90-91. and i mean the whole harness dash, lights,engine. thats why you cant put a 88 cluster on a 91. found out the hard way.
Old Aug 31, 2004 | 08:17 AM
Home Skillet's Avatar
Default Re: (686lsvef)
That sucks, but agree with you on the 2 harnesses being different.
Old Aug 31, 2004 | 09:52 PM
nikitad's Avatar
Default Re: (Home Skillet)
hey-hey.
which harnesses are you talking about? If engine harnesses, then 88 is different, while 89-91 are interexchangeable.
88-91 might have a single difference - some have fast idle valve plug, some don't, but this difference does not affect driveability, and does not throw a code. So for all practical purposes, 89-91 engine harnesses are the same.
Old Sep 1, 2004 | 01:22 AM
1990civicsiguye's Avatar
the 89-91 engine harness are the same its the sub harness in the 88 that is different i belive
Old Sep 1, 2004 | 05:23 AM
jlicrx's Avatar
Default Re: (nikitad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikitad &raquo;</TD></TR><TR><TD CLASS="quote">hey-hey.
88-91 might have a single difference - some have fast idle valve plug, some don't, but this difference does not affect driveability, and does not throw a code. So for all practical purposes, 89-91 engine harnesses are the same.</TD></TR></TABLE>
correct - the 88 didn't have Fast Idle Control Valve - the connector where it plugs into the chassis harness on the driver's side is square 6 wire connector on the 88 and round 8 wire connector on 89-91 - 88 engine harness will only plug right into 88 chassis harness
Old Sep 1, 2004 | 08:41 AM
nikitad's Avatar
Default Re: (jlicrx)
I gotta correct myself. "some of the 89-91" don't have the fast idle plug either. They both have a round plug, but FICV wires are not there. It desn't make a real difference though.
janz3n
Nov 11, 2008 09:43 AM
powerfulperformance
May 31, 2008 10:03 PM
harlen
11
May 29, 2008 09:36 AM
Tippyman
Feb 7, 2007 06:56 AM
2ndGenREX
Jun 9, 2003 12:01 PM
