Untuned B20VTEC makes crazy numbers
Old Aug 30, 2004 | 05:35 PM
CRXEE8's Avatar
Default Untuned B20VTEC makes crazy numbers
I went to a dyno day with the danish Honda club and made some pretty insane numbers with my basic setup. This dyno always put out the lowest numbers in Denmark and 18 other Honda's also made some conservative numbers that day.
I have only had 1 hour on a dyno for some basic tuning where we made the timing very neutral. At that time I had a tiny 2.5" SI Injen intake on and made 195 bhp. I switch that out for my stock intake and the plot is totally fucked up now.
By the look of the plot do I need extra fuel, change the timing or what at 5k? VTEC is at 3500 rpm.
Video of the dyno run
http://www.we-todd-did-racing....DE%3D
The setup:
B20B3 block bored/honed to 85 mm.
IB Spec Wiseco 11.8:1 pistons
Probe Industries Ultra Light rods
Hondata B16A Heatshield
Stock B16A1 head, cams, IM, TB and intake
JG Edelbrock header with IB 2.5" collector
2.5" Carsound cat
3" Thermal cat back
7 lbs Clutch Masters flywheel
ACT 6 puck clutch with Extreme pressure plate
B&M fpr.
Hondata S200 with P28 ECU
Parts on the way:
SMSP B20VTEC header
3" Carsound cat
IB Spec cams
IB Spec Valvetrain
IB Spec valves
STR cam gears
RPM Service 70 MM TB
RLZ intake manifold
RLZ Stage2 B16A head
Modified by CRXEE8 at 11:50 AM 8/31/2004
Old Aug 30, 2004 | 06:51 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Untuned B20VTEC makes crazy numbers (CRXEE8)
Thats very good for what you have, you should be able to get close to 200 with some more dyno time
Old Aug 30, 2004 | 06:55 PM
Propulsion's Avatar
Default Re: Untuned B20VTEC makes crazy numbers (HybridHatch88)
"bored/honed to 85 mm, 11.8:1 pistons"
better tune it well, a little detonation and all your work goes out the window.
Good numbers btw
Old Aug 30, 2004 | 07:18 PM
jdmjopey's Avatar
You need to spend some serious time with that hondata that you have. if you have your vtec set at 3500, you are definetly loosing power from 3500 untill the spot where your computer is used to switching to VTEC. when you adjust the point your vtec hits, you need to adjust the fuel considerably from the point you set it to, to the point the computer is used to. I"ve been spending my saturday mornings on the dyno for the past 2 weeks, its painstaking sometimes, but good luck with the Tuning man.
Old Aug 30, 2004 | 07:41 PM
EKhatch's Avatar
Default Re: Untuned B20VTEC makes crazy numbers (havsom)
Nice numbers but you definitely need some cams. I have seen 205+whp on a stock bottom end B20VTEC with JUN 3's.
When you finish up with the future mods you have listed it should be a nice strong motor as long as the sleeves hold up.
Old Aug 30, 2004 | 07:45 PM
Dan GSR's Avatar
need some cams,
that graph drops off real hard after like 7k
Old Aug 30, 2004 | 08:13 PM
blaster834's Avatar
^ just thinkin that
Old Aug 31, 2004 | 12:26 AM
CRXEE8's Avatar
Default Re: (blaster834)
Thanks for the replys guys....
Yes I know I'm in need of new cams but all the stuff I wrote in the first post are on the way from RLZ and IB. It's already paid so I'm just waiting now for the parts to arrive. I also got me a wide band lambda so I will be tuning on the road and hit the dyno afterwords to tune for max power at full thr.
Old Aug 31, 2004 | 12:45 AM
shorto85's Avatar
You should set your VTEC past redline on a run and then look at the dyno sheet and use that to base where to have VTEC engage at. Having it engage at 3500 RPM is way to early. Your gonna be burning oil too having it engage that early!
Old Aug 31, 2004 | 01:43 AM
CRXEE8's Avatar
Default Re: (shorto85)
Well VTEC was set a 3500 because of the way the old plot looked like with the 2.5" intake. Back then the plot was fine.
Old Aug 31, 2004 | 02:19 AM
EMO-anthony's Avatar
Default Re: (CRXEE8)
Nice numbers!
Old Aug 31, 2004 | 04:42 AM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">Your gonna be burning oil too having it engage that early!</TD></TR></TABLE>
I don't understand this, please explain.
Old Aug 31, 2004 | 07:17 AM
ArinX's Avatar
nice
Get more tunning done, especially since your on stock b20 sleeves. Dont want them to crack on ya.
Old Aug 31, 2004 | 10:49 AM
CRXEE8's Avatar
Default Re: Untuned B20VTEC makes crazy numbers (ArinX)
From my understading what kills the B20 sleeves is detonation. We have set the timing very neutral and I'm running 98 RON fuel so I think I will be fine. So far I have had zero problems with this engine for 8000 miles
Old Aug 31, 2004 | 12:12 PM
BERT-O's Avatar
That graph don't like right, your peaking and dying off rapidly. Try another header or some more tuning.
Then agin, I just read its a bone stock B16 head, makes sense now.
Other than that, congrats
Old Aug 31, 2004 | 03:58 PM
typeR 507's Avatar
Default Re: Untuned B20VTEC makes crazy numbers (BERT-O)
nice #
Old Aug 31, 2004 | 08:11 PM
PHiZ's Avatar
Default Re: Untuned B20VTEC makes crazy numbers (typeR 507)
216 N/M, that's awesome! (159 ft/lbs. )
-PHiZ
Old Sep 1, 2004 | 11:15 AM
CRXEE8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
Other than that, congrats </TD></TR></TABLE>
Yeah the stock head is killing me.... it will great with the IB Spec cams and Brad's Stage2 head. Alot more hp to come
Old Sep 1, 2004 | 11:54 AM
Mr Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXEE8 &raquo;</TD></TR><TR><TD CLASS="quote">From my understading what kills the B20 sleeves is detonation. </TD></TR></TABLE>
My understanding is that the danger is actually the increased stress on the sleeves due to the higher piston side-loading which comes from the LS/VTEC geometry (rod-stroke ratio). Anyone more experienced wanna comment on this?
Old Sep 1, 2004 | 05:42 PM
velocitytrends's Avatar
Nice Numbers! Good luck!
Old Sep 1, 2004 | 07:35 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (velocitytrends)
Nice numbers, but why were you taking a B20 bottom end to 8600 RPM on the dyno?
Old Sep 1, 2004 | 09:38 PM
CRXEE8's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers, but why were you taking a B20 bottom end to 8600 RPM on the dyno? </TD></TR></TABLE>
Well I don't understand that either because my rev. limiter is at 8000 rpm.
Old Sep 2, 2004 | 02:55 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXEE8 &raquo;</TD></TR><TR><TD CLASS="quote">Well I don't understand that either because my rev. limiter is at 8000 rpm.</TD></TR></TABLE>
Thats scary, you shouldn't be going past 8k.. you don't even make power that high. I would find your tuner and PHDTS.
Old Oct 1, 2004 | 08:40 AM
jbcivic8's Avatar
Wow...this makes me excited! I definitely want vtec for my b20 now!
Old Oct 4, 2004 | 06:38 PM
96MidoriHatch's Avatar
Default Re: (jbcivic8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers but you definitely need some cams. I have seen 205+whp on a stock bottom end B20VTEC with JUN 3's.
When you finish up with the future mods you have listed it should be a nice strong motor as long as the sleeves hold up. </TD></TR></TABLE>
jun 3's with a stock bottom end aren't the valve reliefs on a b20 piston a little too small for a cam that size?
The Notorious Frosty
Honda Civic (2006 - 2015)
Jun 21, 2012 08:33 AM
tapiasradiator05
Jun 2, 2012 08:57 AM
RICO_
164
Feb 2, 2011 10:51 PM
d16dcoe45
25
Jan 20, 2007 05:00 AM
98itr0448
Jul 5, 2004 03:08 PM
