Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
uping rim size to half inch..worth it?
Old Aug 30, 2004 | 01:33 PM
azian21485's Avatar
Default uping rim size to half inch..worth it?
i'm currently running 205/50/15 azenis on my stock 15x5.5 rims that weight anywhere from 17-20 lbs (not sure how much they weigh)..anyways i can get a set of 15x6 rims that weigh 15lbs pretty cheap and i'm planning on running the same tires..this is strictly for autocross use and keep in mind i'm broke
question is, is half an inch in width going to improve grip noticebly? or should i just save up for a proper set of wheels?
and yes i'm trying to get in as much seat time possible
Old Aug 30, 2004 | 01:44 PM
.RJ's Avatar
.RJ
Default Re: uping rim size to half inch..worth it? (azian21485)
15x7's, dont waste your time w/ the 6" wheels.
Old Aug 30, 2004 | 01:52 PM
Sean O'Gorman's Avatar
Yeah, you should be able to find a used set of K1s or other similar 15 X 7s for a fairly low price.
Old Aug 30, 2004 | 02:13 PM
Xian's Avatar
Default Re: uping rim size to half inch..worth it? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">15x7's, dont waste your time w/ the 6" wheels.</TD></TR></TABLE>
yep, running a 7" wide wheel with the Azenis makes all the difference in feel.
Christian
Old Aug 30, 2004 | 02:39 PM
Mike_C's Avatar
is the benefit of a 7 over 6.5 really that great?
Old Aug 30, 2004 | 03:36 PM
azian21485's Avatar
Default Re: (Sean O'Gorman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean O’Gorman &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, you should be able to find a used set of K1s or other similar 15 X 7s for a fairly low price.</TD></TR></TABLE>
yea i see them for some pretty good prices even tho a lil expensive for my current situation..problem is they are NEVER in the lug configuration i need (4x114.3)...the only other rim i could think of that is around the same price range is the prelude si rims at 15x6.5 but those damn things weigh 23 lbs lol
Old Aug 30, 2004 | 04:18 PM
I feel your pain. Try finding lightweight 14X6 and 14X7 wheels in the 5X114.3 bolt pattern. I'm stuck with 16lb front wheels and 19lb rear wheels for auto-x because theres nothing readily available for my MR2.
The Dirty EJ1
Jan 27, 2007 05:18 AM
Pondus
Apr 13, 2004 09:00 AM
ITR Factor
Feb 18, 2004 06:10 PM
piotrush
Dec 13, 2003 06:59 PM
dohc_hatchieback
20
Nov 18, 2003 09:06 AM
