Where to buy b18c5
like the title says, where is a good place to buy a USDM ITR motor?? or well . a good question is to be specific about why i want a USDM ITR motor instead of JDM ITR
if i swapped a 96+ JDM ITR motor into any 92-95 body, and it was all stock (minus bolt -on's i suppose) would it pass cali smog (for any cali residents) cuz if so, then it doenst matter if its USDM/JDM ITR to me. .
but im not sure, i was guess no... so thats why i wanted a USDM motor . . that'll pass for sure . .
so yeah, basically not sure / / ???
You can get JDM engines to pass the BAR certification process, as long as there was a USDM counterpart, so a JDM B18C-R would be equivalent to a USDM B18c5.
As long as the motor is newer than the car and is hooked up like it'd be in a USDM ITR (obd2, etc), then you should have no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 »</TD></TR><TR><TD CLASS="quote">like the title says, where is a good place to buy a USDM ITR motor?? or well . a good question is to be specific about why i want a USDM ITR motor instead of JDM ITR
JDM Engines can be done.
Check here:
https://honda-tech.com/zerothread?id=906684
</TD></TR></TABLE>JDM Engines can be done.
Check here:
Hoodwinked
May 23, 2004 10:55 PM
Filliam H. Muffman
19
Jan 23, 2003 06:58 AM
