bored k24
Spongebrad Squarepants
well my plans are to go with k24 bottom end k20a2 head or just go with k20a (itr) im just doing a little thinking before i go with one or the other
Taking a K24 block out 3mm to 91mm could be a little dangerous. What ever you do, you will need custom pistons. K20A2 is the hi-performance head and is the only one to use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A-AllMotor »</TD></TR><TR><TD CLASS="quote">Why the head conversion?
And if it was me, I'd swap the k24 head for k20a1.</TD></TR></TABLE>
You are confused. a1 cams suck. flow/vtc is not as good either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">sleeve it , bore it to 91 , stroke the **** out of it and put huge *** numbers down!!!</TD></TR></TABLE>
I would destroke it - piston speeds are already rediculously high on k24 blocks...tend to kill power after 7500 rpm anyways
i think stroke on the k24s is 99mm to begin with (R/S ratio is
EDIT - I do agree with sleeving it - especially if you are going with a 91mm bore
)EDIT - I do agree with sleeving it - especially if you are going with a 91mm bore
Did you realize that that the K24 has the same r/s ratio as the b18A? It is 1.54 to 1.
The GSR is only 1.58 so pretty darn close. We are developing a 95mm crank for that motor, however, for those that want to destroke it.
yeah, i don't think that the problem is so much the r/s ratio as it is the (longer) distance of the rotational mass from the crank centerline; vibration and harmonics might be harsh at higher rpm.
good deal on the 95mm crank development.
Well I know Skunk2 does need to inspect their rod bearings after each event due to the stroke. I don't know the specs of their motor though. They may have stroked it even more.
yea i plan on sleevin it if i do go with the k24 bottom end and yes i thought about destroking it because of the torque because that is my main purpose is to get the power to the ground id like to have some big numbers but id rather have decent numbers that put the power to the ground instead of spinnin or wheel hoppin
JDM00SI
Dec 10, 2005 08:35 PM
