mini-me finally finished
Old Aug 30, 2004 | 06:56 AM
93slmdcvcsi's Avatar
Default mini-me finally finished
I just put my mini-me together and everything is great. here is a pic of the setup.
y8 head, head gasket, and manifold.
d16a6 block w/ zc pistons and rods
Old Aug 30, 2004 | 07:06 AM
Layziebtnh055's Avatar
Default Re: mini-me finally finished (89cvchb)
nice setup i have a mini me too, what stronger pistons and rods would fit in a d15b2 block
Old Aug 30, 2004 | 09:16 AM
lunchboxEF91's Avatar
^^^i would like to know this too.^^^
Old Aug 30, 2004 | 09:33 AM
4drEF's Avatar
Keyboard Humorist
Default Re: mini-me finally finished (Layziebtnh055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziebtnh055 &raquo;</TD></TR><TR><TD CLASS="quote">nice setup i have a mini me too, what stronger pistons and rods would fit in a d15b2 block</TD></TR></TABLE>
He uses the ZC ones so I'm guessing you could use A6 rods?
If so, then you could also use LS rods (notching and rubusing required).
Old Aug 30, 2004 | 09:34 AM
Default Re: mini-me finally finished (mrspeaker)
I havent wired vtec up yet, i was gonna let the motor break in a little before i hook it up, but i will be using a msd rpm activated switch pn:8950, make sure you buy the correct pills for your setup
Old Aug 30, 2004 | 09:35 AM
DieMaster's Avatar
Needs to be About 20% Cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cvchb &raquo;</TD></TR><TR><TD CLASS="quote">I just put my mini-me together and everything is great. here is a pic of the setup.
Is that even a VETC head? i see no VETC (spool) solnoid
Old Aug 30, 2004 | 09:42 AM
Default Re: mini-me finally finished (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">
Is that even a VETC head? i see no VETC (spool) solnoid </TD></TR></TABLE>
if you know anything, then you would know that a sohc vtec head has the spark plugs in the from and the vtec solenoid is under the breather filter
Old Aug 30, 2004 | 09:49 AM
Doctor CorteZ's Avatar
Y8 has it on backside of the block.
Old Aug 30, 2004 | 09:57 AM
Here is the pic of the vtec solenoid
Old Aug 30, 2004 | 10:42 AM
Curtis2kul's Avatar
clean , i like
Old Aug 30, 2004 | 11:09 AM
d357r0y's Avatar
Looks good!
Mainly cause that's what my engine looks like
keep us posted on those pistons with that head. Also do you think you'll have any problems if you decided to run a higher lift cam with those pistons?
Old Aug 30, 2004 | 04:32 PM
DieMaster's Avatar
ok your right Now that i think about it, i thought all VTEC head's had the VETC solonad on the side like the DOHCs do but come to think about it, i never seen a VETC SOHC head and your right also about the plug wires.
Old Aug 30, 2004 | 04:38 PM
senpai's Avatar
What's your compression with those pistons?
Old Aug 30, 2004 | 05:02 PM
Bserieskllr's Avatar
Default Re: mini-me finally finished (maztur)
he should have around 12.5:1 if im not mistaking...im just dissaponted that its gonna be running a rpm switch for vtec ....been there done that it sucked thats all i have to say but the swap looks nice and clean....oh what ecu are you running?
Old Aug 30, 2004 | 05:20 PM
Change's Avatar
Default Re: mini-me finally finished (Bserieskllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">he should have around 12.5:1 if im not mistaking</TD></TR></TABLE>
how does it jump that much from what the zc had?
Old Aug 30, 2004 | 05:28 PM
Default Re: mini-me finally finished (pSI civic)
because the zc has alot bigger of a combustion chamber then the sohc's.
Old Aug 30, 2004 | 05:35 PM
Change's Avatar
the zc was 9.1:1-9.5:1 right? thats a big jump...
Old Aug 30, 2004 | 05:40 PM
lhd dc2's Avatar
nice swap.
Old Aug 30, 2004 | 05:41 PM
yea somwhere around there..i just got me some zc pistons for $80 cant wait till they go in...
Old Aug 30, 2004 | 05:44 PM
Change's Avatar
well that is a lot cheaper then arais or some other brand but how much nos can they take? what kind of power would you say that makes? can you run it on 93 octane?
Old Aug 30, 2004 | 05:49 PM
JohnnyB70's Avatar
What ECU and Distributior are you using?
Old Aug 30, 2004 | 05:53 PM
yes it can be run on 93 octane....you could probablly squezze at the most a 55 shot with that kind of compression but your gonna have lots of tuning to do and probablly run some race gas. well they say 5% power increase for each point over stock.....so take a stock d16z6 125hp put zc pistons that bumps around 3 points of compression so around a 18hp gain i come out with flywheel of coarse. now im not saying your guranteed 18hp with them but ill find out when i put mine in.
Old Aug 30, 2004 | 06:00 PM
Change's Avatar
that high of compression sounds to high for me and a daily driven car...
would be fun though...
Old Aug 30, 2004 | 06:33 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">im just dissaponted that its gonna be running a rpm switch for vtec </TD></TR></TABLE>
I agree why cut short now and give up? You obviously did this for more power so why not get the most?
Old Aug 30, 2004 | 06:42 PM
SloVXHatch's Avatar
Nice swap! How long did it take from start to finish?
