What is involved in replacing timing belt tensioner?
Old Dec 5, 2001 | 08:30 AM
Bunta's Avatar
New User
Default What is involved in replacing timing belt tensioner?
I am approaching 90K on my ITR and asked Mike K what to service beyond the timing belt and water pump. He suggested that I replace the timing belt tensioner (TBT) as well. What exactly am I replacing? Is it the TBT bolt, the pulley, and the spring?
Also, does the water pump come with the o-ring that fits between the pump and the block?
Old Dec 5, 2001 | 08:55 AM
Mike K's Avatar
Default Re: What is involved in replacing timing belt tensioner? (Bunta)
Once you're in there it's easy to replace. Loosen the 14mm bolt, and put the new one on.
The new water pump comes with the gasket. When you said o-ring, I thought you meant the o-rings that go on the water pipe under the intake manifold.
Old Dec 5, 2001 | 08:56 AM
Bunta's Avatar
New User
Default Re: What is involved in replacing timing belt tensioner? (Mike K)
Thanks Mike
hondahenry
Jul 19, 2015 02:36 AM
Tina Saunders
Jan 21, 2013 10:37 PM
NFrank89
Oct 19, 2010 06:59 AM
5.56
Jun 17, 2009 05:19 PM
Ritchie
Feb 5, 2007 08:06 PM
