Begining Stages of My N/A Setup...
Old Aug 30, 2004 | 01:17 AM
DarkSol97's Avatar
Default Begining Stages of My N/A Setup...
Id like to share with you guys my first stage of my N/A project in the works...
I finally completed my bottom half portion of my build which includes:
- B18c1 block bored out to 81.5mm.
- Balanced Crankshaft.
- Eagle Rods
- JE custom coated 12.5 : 1 compresson forged pistons.
- Welded Nuformz block gaurd welded to the block.
- New OEM oil & water pump.
- OEM rod & main bearings.
- AEBS main studs.
Sorry for the crappy pics...I can't afford a new camera. Because all of my money is going into the build.
Now that my bottom half is completed, I now focus my attention to the headwork. I will update with more pics later on as the build progress.
Modified by DarkSol97 at 7:22 PM 8/30/2004
Old Aug 30, 2004 | 01:31 AM
OLM-02R's Avatar
nice looking block man... keep us updated with the build... are you doing all the work urself ??
Old Aug 30, 2004 | 04:23 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (OLM-02R)
What all are you going to do to the head, i.e. port work, cams, valvetrain etc.?
Old Aug 30, 2004 | 04:44 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Begining Stages of My N/A Setup... (DarkSol97)
looks good so far keep this updated..
Old Aug 30, 2004 | 08:26 AM
BigBodySmith's Avatar
very clean looking, really like it, so what are the plans for the head??? keep us updated!!!
Old Aug 30, 2004 | 09:37 AM
Rick Solis's Avatar
Damn... That block looks brand new...
Did you spray it silver?
Old Aug 30, 2004 | 01:36 PM
H22A-AllMotor's Avatar
Default Re: Begining Stages of My N/A Setup... (Rick Solis)
That must be one of the cleanest blocks I've ever seen.
Old Aug 30, 2004 | 02:05 PM
Draglab01's Avatar
Looks sweet man. I'm doing almost the identical setup accept with arias 81.5mm @ 12:1. What cams are you goin with?
Old Aug 30, 2004 | 03:51 PM
TrnsferErr's Avatar
very nice
Old Aug 30, 2004 | 05:26 PM
Default Re: Begining Stages of My N/A Setup... (TrnsferErr)
Do you have any plans for the head?
Old Aug 30, 2004 | 05:44 PM
evilone's Avatar
Default Re: Begining Stages of My N/A Setup... (H22A-AllMotor)
looks sick.....what cams are you thinking of running?
Old Aug 30, 2004 | 05:53 PM
DarkSol97's Avatar
Thanks for the comments. As for the head portion of this buildup it will include the following:
Head: 99 ITR PR3-4 Head
Internals: Rev dual valve springs
Rev Titanium Retainers
Rev Flat Top Stainless Steel Valves
Ferrea Steel Valve locks
Skunk 2 Stage 2 Camshafts
ARP head studs
STR Cam Gears
JG 65mm TB
AEBS Intake Manifold
I'll hopfully have the head put together within a few days and with pictures of the progress to follow.
Old Aug 30, 2004 | 06:45 PM
RobbieG35's Avatar
12 Years Strong
Sounds like a strong set-up you got planned, keep us updated
Old Aug 30, 2004 | 06:49 PM
Default Re: Begining Stages of My N/A Setup... (HybridHatch88)
People say that it's not a good idea to beef up your valves with skunk2 stg2 cams...
But I'm running skunk2 stg2's with .1mm oversized stainless steel valves, have had no problems, and they've been installed for the past 5 months. Just thought I'd clear that up for anyone who might have considered it.
Old Aug 30, 2004 | 07:38 PM
Icey112's Avatar
so clean
Old Aug 30, 2004 | 08:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkSol97 &raquo;</TD></TR><TR><TD CLASS="quote">I finally completed my bottom half portion of my build which includes:
- Eagle Rods
- AEBS main studs.
Modified by DarkSol97 at 7:22 PM 8/30/2004</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkSol97 &raquo;</TD></TR><TR><TD CLASS="quote">Head: 99 ITR PR3-4 Head
ARP head studs
STR Cam Gears
JG 65mm TB
Damn, this is almost the exact set up I am building, check the sig!!!
vvv
Old Aug 30, 2004 | 09:59 PM
anothersickhatch's Avatar
Default Re: Begining Stages of My N/A Setup... (BigBodySmith)
how the hell do you get the block to look like that? paint??
Old Aug 30, 2004 | 10:22 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: Begining Stages of My N/A Setup... (anothersickhatch)
impressive
Old Aug 30, 2004 | 10:43 PM
DarkSol97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothersickhatch &raquo;</TD></TR><TR><TD CLASS="quote">how the hell do you get the block to look like that? paint??</TD></TR></TABLE>
Had the block painted with Duplicolor "Aluminum" engine heat paint
HOM DON
Mar 7, 2011 09:44 PM
GiNuWiNe
Mar 15, 2006 09:32 PM
PM-Performance
Nov 30, 2003 01:49 PM
PM-Performance
Nov 29, 2003 09:49 AM
sweet
Apr 21, 2003 06:57 AM
