OMG! What happened to my plugs!!!
Old Dec 5, 2001 | 08:19 AM
HX_Guy's Avatar
Default OMG! What happened to my plugs!!!
I have never in my life seen this!
What caused the ceramic part to break? WTF!
Also here is the color of the plug...it only has 73 miles on it so it might be to early for it to show anything.
Old Dec 5, 2001 | 08:25 AM
Tomakit's Avatar
Default Re: OMG! What happened to my plugs!!! (HX_Guy)
I know you said you were running 89 octane...did you ever throw in octane booster? Cause if you did, your plugs (2nd pic) will look exactly like that.
I can't tell if there is detonation, cause the pic is a little blurry.
As for the first pic...i have never seen anything like that.
Tom
Old Dec 5, 2001 | 08:29 AM
HX_Guy's Avatar
Default Re: OMG! What happened to my plugs!!! (Tomakit)
Yes I threw in some NOS Octane Booster...Iguess Ill have to wait till I go through this tank of gas and then fill up again to get a true reading.
Old Dec 5, 2001 | 08:41 AM
Tomakit's Avatar
Based on what the guys said in the FI forum...i think ur just fine. Octane booster will always make ur plugs red, and you'd be able to tell if you had detonation right away. Any silver/white specs on the electrode? If so, then you prob have some detonation. A
And it looks as though you mighta broken the first plug. So...problem solved.
Have you played with your fuel at all since putting it all together?
Tom
[Modified by Tomakit, 9:42 AM 12/5/2001]
Old Dec 5, 2001 | 08:43 AM
HX_Guy's Avatar
Theres no white/silver specs on the electrode at all.
As for the pllugs breaking, I think it was the socket. I talked to this guy I know and he said he's seen it happen before if the socket isnt long enough...it pushes down on the ceramic part and cracks it! Luckily I have another set of plugs in the car! But no socket! Blah!
Old Dec 5, 2001 | 09:43 AM
MrFatBooty's Avatar
Where'd the rest of the ceramic go? Not into the engine I hope...
Old Dec 5, 2001 | 10:02 AM
HX_Guy's Avatar
Default Re: OMG! What happened to my plugs!!! (MrFatBooty)
No, it fell on the ground after I tok the plug out of the socket.
Old Dec 5, 2001 | 10:29 AM
smerk's Avatar
New User
Did the ceramic break off on all the plugs or just one? I'm surprised you didn't see or feel or hear anything when if it broke off during installation. As far is the color of the plugs go, it looks just fine since it looks tan.
Old Dec 5, 2001 | 10:30 AM
HX_Guy's Avatar
Default Re: OMG! What happened to my plugs!!! (smerk)
1 was broken (the one in the picture), 2 have cracks, and 1 is ok.
Old Dec 5, 2001 | 04:59 PM
Project X's Avatar
Wow! That's pretty scary. It's good that none of the ceramic fell in the hole.
What did you use to tighten the spark plugs? Did you torque it? Maybe you've tightened it too much.
Old Dec 5, 2001 | 05:06 PM
MrBite's Avatar
Looks like you need to be a liiiiiiittle bit nicer to your engine during break-in
afnan
Jan 17, 2014 06:08 AM
EGhatchLSV
Jan 31, 2008 02:01 AM
ophdehEEzY
Apr 27, 2003 03:20 PM
nicksweetlude
Feb 25, 2002 06:05 PM
B17aTrbo
Oct 29, 2001 04:14 PM
