Oil in spark plug cylinders.
Old Aug 29, 2004 | 08:32 PM
7NeverDies's Avatar
Default Oil in spark plug cylinders.
OK did a search on this problem, yielded the same things, but with no updates on to if it fixed the problem.
My problem was that my car was hestitating, so i pulled the plugs... the wires and the plugs and the shaft for the plugs on the #2 & #4 cylinders were full of oil. #1 and #3 had some oil in them, regardless, all of the plugs were oil coated. So i replaced them, but my concern now is, why?
Well, i know that the valve cover has gaskets/grommets that go on each of the walls of the cylinders. So i plan on taking that off and replacing.
Also, oil can mean that the valve guides are worn or that my rings are shot. So i'm hoping this is not the problem.
SO anyone thats had this, remedied it, or whatever.. make a post please.
Thanks in advance.
Old Aug 29, 2004 | 08:44 PM
hybrid1990crx's Avatar
Default Re: Oil in spark plug cylinders. (7NeverDies)
Do you mean the oil was on top of the plugs or on the electrode? If on top i say replace the 4 rubber rings under the valve cover. I had to do this before on my old a6.
Old Aug 29, 2004 | 08:54 PM
HondaKPX's Avatar
Default Re: Oil in spark plug cylinders. (hybrid1990crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean the oil was on top of the plugs or on the electrode? If on top i say replace the 4 rubber rings under the valve cover. I had to do this before on my old a6.</TD></TR></TABLE>
Old Aug 29, 2004 | 08:57 PM
B16 CRX's Avatar
I had this same problem with my D16, I replaced the rubber rings it solved my problem. I was told that you can expect this on hight milage motors
7NeverDies's Avatar
it was on both.
murrellington
Mar 21, 2016 05:11 PM
smetzger
Mar 31, 2008 10:15 AM
AznBlueBoy
Jun 5, 2004 01:53 PM
sacredc0w69
May 24, 2003 06:34 AM
eastsidemags
Mar 22, 2002 01:22 PM
