do i have bent valves or is the shop tryin to get money from me?
Old Aug 29, 2004 | 06:48 PM
lemongreenhatch's Avatar
Default do i have bent valves or is the shop tryin to get money from me/////////////////////||||||||||||||||
ok i took my car for a leak down test so i was leaking everywhere now shop says i have bent valves but yet when it starts there is no odd noise from the head they want to charge me 150 to take off the head to inspect i said i would do it my self they said to take my car do it and bring it baack they wont let me do it there thing is the shop is like 30 miles from my house i got it towed i thinke they just want some more money i think its rings thing is i just took it to get my vafc tunned
leaking
dip stick
tb
im
Old Aug 29, 2004 | 07:25 PM
chero112's Avatar
Default Re: do i have bent valves or is the shop tryin to get money from me/////////////////////||||||||||||
did you do a compression test if not you need to do so.
Old Aug 29, 2004 | 07:43 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote"> did you do a compression test if not you need to do so. </TD></TR></TABLE>
Yup. Quickest way to tell you if it is top or bottom.
Old Aug 29, 2004 | 07:44 PM
no i didnt ill tell them tommorow but i think thevalve seals are out cuz there was air out of tb
Old Aug 29, 2004 | 09:43 PM
SiR831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorman-type-r &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt ill tell them tommorow but i think thevalve seals are out cuz there was air out of tb</TD></TR></TABLE>
what percentage was the leakdown? you said air is coming out of the tb possibly intake valves?
Old Aug 29, 2004 | 09:45 PM
they said it was supose to be 100% it was at 83 81 79 89 thats each cyl.
Old Aug 29, 2004 | 10:47 PM
nY's FiNeSt's Avatar
doing a compression test is not always guaranteed to tell you if you have bent valves.
i ran 210's across the board, then took my head off and i had 7 bent exhaust valves
Old Aug 30, 2004 | 12:43 AM
chris_m's Avatar
* B A N N E D *
Simple way to check for bent valves. Poor water into the ports when the head is on it's side. If water poors out of the valves there is your bent valve. Nice and easy
Old Aug 30, 2004 | 12:59 PM
just askin wouldnt the valves tap if they were bent
Old Aug 30, 2004 | 04:04 PM
newupdate i told the shop to take out my spark plugs and put new onescuz they didnt pay attention the first time when i told them they were fouled so they tunned it dynoed it 180hp not what i was expecting with 12:5:1 pistons cometic head gasket stage 3 crower cams rev valve tarain was expecting around 220 but i still could have bad rings shop said they thought had stock cams maybe that had an effect they told me to drive it around and theyll retune it
Old Aug 30, 2004 | 06:14 PM
asubennett's Avatar
What type of dyno were those numbers produced on? What type of fuel used? What type of management used for tuning?
Old Aug 30, 2004 | 07:28 PM
dyno i dont know its a import shop that specilizee in hondas if that helps
fuel i dont i got the shell with1/2 tank so not shure if its 93 octane its tunned with vafc i know hondata is better but its all i could afford
Old Aug 31, 2004 | 12:26 PM
Tad's Avatar
Tad
dude no shop is going to let you work on your car on their facilities.
there are liability concerns incase you get hurt,
and not to mention they payed all that money for those facilities.. why would they let you use em just so you can get out of paying them??
so dont be suprized about that part.
whether they're honest or not, I couldnt say.
JBirch_97Prelude
Mar 9, 2021 03:01 PM
The Dirty EJ1
Jun 30, 2008 12:37 AM
leeminho86
May 18, 2006 08:14 AM
SiRGodfather
Jun 1, 2004 11:10 PM
Dr Pooface
Nov 18, 2003 04:29 AM
