QUESTION?? is the 88-89 integra classified as a zc motor?
Old Dec 5, 2001 | 06:35 AM
v-tec crx's Avatar
New User
Default QUESTION?? is the 88-89 integra classified as a zc motor?
is this a zc motor? same specs? if it is, what all is needed to go in a 88 crx si? can the stock mounts work.. thanks
Old Dec 5, 2001 | 06:42 AM
Chugger's Avatar
Default Re: QUESTION?? is the 88-89 integra classified as a zc motor? (v-tec crx)
damn champ i see you got plans
are you refering to the 1.6 or 1.8 im not certain but i think that the 1.6 were refered to as the zc id check the the crx hybrid board
lata
chris
Old Dec 5, 2001 | 06:58 AM
crx(gator)'s Avatar
nope the 88-89 teg motor is a d16a1 and is rated at 118hp, it has lower compression and a less agressive cams, it will not bolt in to a 2nd gen crx and would not be worth it anyway...this is actually a harder swap for a 1st gen crx because of the little bit of extra wiring that has to be done...
Old Dec 5, 2001 | 11:12 AM
v-tec crx's Avatar
New User
Default Re: QUESTION?? is the 88-89 integra classified as a zc motor? (crxgator)
THANKS FOR THE TIP!!
Old Dec 5, 2001 | 02:36 PM
crxgurlllll's Avatar
Its Designated ZC in Japan 1st Gen Tegs but has the same mounting as teh d16a1
temporarysuicide
Oct 31, 2006 12:48 PM
joel_wilson
Jul 21, 2004 10:29 PM
wtfang
Apr 22, 2004 02:43 AM
86CRXSi
Jun 4, 2002 08:10 AM
AmauryR
Jan 17, 2002 05:00 PM
