FS: 2.5" Test Pipe
Old Aug 29, 2004 | 04:04 PM
GeeReg's Avatar
Default FS: 2.5" Test Pipe ***SOLD***
***SOLD***
I have a used 2.5" test pipe for sale. It is 17.5" long and made from aluminized steel. It does not have an O2 bung.
Modified by GeeReg at 6:54 PM 1/18/2005
Old Aug 29, 2004 | 04:19 PM
stick's Avatar
Default Re: FS: 2.5" Test Pipe (GeeReg)
will this fit JDM 4-1 header collector?
is it 2.5" in/out?
im interested.
Old Aug 29, 2004 | 04:26 PM
lagingtorpe's Avatar
i have a 96 hatch with type r swap and regular exhaust. will this connect the exhaust to the stock type r header?
Old Aug 29, 2004 | 04:55 PM
GeeReg's Avatar
Default Re: FS: 2.5" Test Pipe (stick)
Stick, yes it will fit the JDM 4-1 and it is 2.5" in/out.
lagingtorpe, I will have to look into that because I am not sure at the moment.
Old Aug 29, 2004 | 04:57 PM
Padawan's Avatar
Darth ModerVader
I just wanted to add that I helped Greg prep this, and I used a Dremel to clean and smooth the interior of the inlet and outlet.
As for the fitment questions, unfortunately we don't have specific information on all of the combinations of header/exhausts this will fit. This test pipe is approximately the same length as a USDM Integra cat (17.5"). It has a full 2.5" inlet, so it should bolt-up to any JDM-sized header. The outlet is also 2.5", and will bolt to almost any Integra B-pipe with a traditional 3-bolt flange. However, the length may or may not be correct for a particular application, and we haven't done any test-fitting.
I encourage everyone to measure their current setup, or research their specific needs in order to be certain this piece will be the correct length.
Old Aug 29, 2004 | 05:03 PM
GeeReg's Avatar
Padawan's advice is probably best, that you measure your current setup to make sure it will fit. I wouldn't want to tell you it will, then have you get it and realize you can't use it.
Old Aug 30, 2004 | 10:11 AM
stick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeReg &raquo;</TD></TR><TR><TD CLASS="quote">Padawan's advice is probably best, that you measure your current setup to make sure it will fit. I wouldn't want to tell you it will, then have you get it and realize you can't use it. </TD></TR></TABLE>
IM sent.
it will work for me.
Old Aug 30, 2004 | 10:48 AM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stick &raquo;</TD></TR><TR><TD CLASS="quote">IM sent.
it will work for me.</TD></TR></TABLE>
Replied
Old Sep 19, 2004 | 01:41 PM
GeeReg's Avatar
Still for sale.
Old Oct 1, 2004 | 11:13 PM
WHITE DEATH's Avatar
Very interested im sent
d0nkeyxPunch
Jun 7, 2004 10:15 PM
Heisdan
Apr 13, 2004 08:28 PM
pinota
Oct 28, 2002 11:00 AM
Ausmith
Oct 11, 2002 04:36 AM
Evil DOHC
Jul 31, 2001 10:16 AM
