ek non srs wheel into an ef?
i wanted to know if a ek non srs steering wheel would fit a ef? is it a direct bolt on or does it need any modification? any specs and any info would help alot? i know that the non srs ITR wheel fits the ef... so i wanted to know if the ek would fit also?... thanks anyone...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 »</TD></TR><TR><TD CLASS="quote">i wanted to know if a ek non srs steering wheel would fit a ef? is it a direct bolt on or does it need any modification? any specs and any info would help alot? i know that the non srs ITR wheel fits the ef... so i wanted to know if the ek would fit also?... thanks anyone...
well the ITR wheel is not really a direct bolt on. yes, it bolts to the steering shaft but it wobbles on the EF steering shaft. I had to modify the shaft to let the wheel sit better to let the nut to thread properly and the steering wheel slightly as well. It will probably be the same situation with an EK, but not 100% sure about that
</TD></TR></TABLE>well the ITR wheel is not really a direct bolt on. yes, it bolts to the steering shaft but it wobbles on the EF steering shaft. I had to modify the shaft to let the wheel sit better to let the nut to thread properly and the steering wheel slightly as well. It will probably be the same situation with an EK, but not 100% sure about that
did you get my email about what i have for SALE??
What i have for sale:
SSR EX-C 15's 4x100 super fins are $600.00 no tires
JDM front end conversion with all the lights (front and back) $750.00(sold)
90-91 shell body $300.00(sold)
Modified by bebeon_ek at 3:44 PM 9/11/2004
89ED
Jan 20, 2019 09:28 PM
flatblackracing
Mar 9, 2006 07:51 AM
