Intake manifold question?
Old Aug 29, 2004 | 01:47 PM
chero112's Avatar
Default Intake manifold question?
I just get my throttle body bore out to 64mm and my question is it worth get my stock intake manifold bore out to match or should I just buy an aftermarket one like skunk2. This is for a 2000 gsr.
Old Aug 29, 2004 | 02:17 PM
chero112's Avatar
Default Re: Intake manifold question? (chero112)
bump
chero112's Avatar
need some info.
Old Aug 29, 2004 | 03:36 PM
zad5's Avatar
how much would it cost to port match id buy an intake manifold if i were you port matching is how much 200 bucks or so get the wicked-industries one the castings a little better and i believe cheaper.
Old Aug 29, 2004 | 07:18 PM
chero112's Avatar
Default Re: (zad5)
I paid 100 bucks for the throttle body and 60 bucks for the intake manifold So I'm stock between a rock and a hard place. I was thinking about getting the skunk2 manifold but when I spoke to the person at the machine shop he said it it would be cheaper to just match my stock manifold so here I'm am
Old Aug 29, 2004 | 11:16 PM
Supahr_Ed's Avatar
the inlet on the skunk2 and gsr is the same. If your TB is only going to be bored to 64mm then you can pretty much DIY with a dremal or something. But most people go with the S2 for the GSR to elimnate the secondary. If you dont plan to elimnate the secondary, then have them port the gsr.
Old Aug 30, 2004 | 06:21 PM
chero112's Avatar
Default Re: (Supah_Eg6)
okay thanx for the info
Old Aug 30, 2004 | 06:30 PM
14bcoupe's Avatar
Default Re: (chero112)
you should just port match the intake manifold yourself with a dremel,its really easy, i did this to my manifold the first time i used a dremel and came out a nice 2mm over. or get the skunk2 mani but then you gotta change your p72 ecu to a p28 chipped, but in the end the sk2/p28 combo will show better numbers.
Old Aug 30, 2004 | 09:11 PM
chero112's Avatar
Default Re: (14bcoupe)
I really didn't know what to do, I did a search not to much info on this topic. I was planning on getting a skunk2 manifold but I though maybe boring out the stock one would be just fine. You see my goal is to get 210 or even 215 to the wheels that's it.
If I was to put a skunk2 manifold wouldn't that hurt low end proformance because it's elimnating the secondaries?
Old Aug 30, 2004 | 11:12 PM
OLM-02R's Avatar
yeah just port match the im urself... its pretty easy... gl
Old Aug 31, 2004 | 01:16 PM
chero112's Avatar
Default Re: (OLM-02R)
thanx for the info. All I need is a dramel with what type of bit also about hoe long will it take.
Old Sep 1, 2004 | 06:56 PM
14bcoupe's Avatar
i start with the dremel #408 then finish it with #432.
or use #952 then finish it off with #432. get them at home depot.
takes pretty long,but patience is your friend cause its a free hp mod.
i have always done this myself to my manifolds and also good to port match your head also if you have it out.
Old Sep 2, 2004 | 02:49 PM
chero112's Avatar
well I just finshed up with installing the valetrain, I didn't do it. I just added itr valves, crower springs and retainers also bored out the throttle body. My next thing is to get a set of cams and do something with the manifold.
But back to doing the manifold I'll give it a shot, but how far over can I go .3 over or less then that...
Old Sep 3, 2004 | 02:52 AM
hyperazn108's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14bcoupe &raquo;</TD></TR><TR><TD CLASS="quote">you should just port match the intake manifold yourself with a dremel,its really easy, i did this to my manifold the first time i used a dremel and came out a nice 2mm over. or get the skunk2 mani but then you gotta change your p72 ecu to a p28 chipped, but in the end the sk2/p28 combo will show better numbers.</TD></TR></TABLE>
if u get a skunk2 mani you HAVE to chip the ecu???
Old Sep 9, 2004 | 05:16 PM
fuck honda-tech's Avatar
Default Re: (hyperazn108)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperazn108 &raquo;</TD></TR><TR><TD CLASS="quote">
if u get a skunk2 mani you HAVE to chip the ecu???</TD></TR></TABLE>
Steeve_Civic
Jan 19, 2014 04:28 AM
gezzuzz
Apr 13, 2008 07:40 PM
dc4teg95
Feb 28, 2007 10:58 AM
danteisme
Feb 26, 2004 04:28 PM
92DSeries
Feb 25, 2003 09:36 PM
