moonroof jumpy
Old Aug 29, 2004 | 01:20 PM
StrtMeUp01's Avatar
Default moonroof jumpy
my moonroof on my integra is pretty jumpy, when it slides back while its opening up, it short hops, then when closing it, it slides smooth. Im guessing I just need to clean dried grease in the tracks and reapply some to smooth it out... is this the correct assessment?
Old Aug 29, 2004 | 01:26 PM
G-bonic's Avatar
Hijacked
Default Re: moonroof jumpy (StrtMeUp01)
grease it up or check the tooth of it and the sliders.... lube it
Modified by Stock_LS at 5:38 PM 8/29/2004
Old Aug 29, 2004 | 02:09 PM
patmcd's Avatar
Default Re: moonroof jumpy (Stock_LS)
This is a very common problem. And as far as I can tell there is no real good fix for it. But remove and rocks/dirt in the tracks and give it a good lube and it should work better.
Old Aug 29, 2004 | 02:32 PM
HeyMikeyyyy's Avatar
Default Re: moonroof jumpy (patmcd)
some wd40 should do i think lol
Old Aug 29, 2004 | 04:06 PM
timmy8151's Avatar
Default Re: moonroof jumpy (HeyMikeyyyy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeyMikeyyyy &raquo;</TD></TR><TR><TD CLASS="quote">some wd40 should do i think lol </TD></TR></TABLE>
WD40 is good for cleaning the tracks, but put on some white lithium grease to lubricate it. Only problem with lithium grease is that it attracts a lot of particles.
THE LORD OF CHAOS
Apr 6, 2005 02:11 PM
MissLady
16
Mar 3, 2005 09:17 PM
moleodonuts
20
Jun 26, 2004 07:49 AM
CNSK
Sep 23, 2002 02:57 PM
